-had a 15 inch flat monitor and replaced it emachines e230h model -screen stops with the message Windows fail to open with a message what mode of OS to run. selected normal mode and another time safe mode with the same resulting message. -if it is a driver issue how can i load the correct driver with a non working display? Not an expert computer tech but willing to know/learn options. Please I need help. ron m.
SOURCE: eMachines 15
Seems like a old problem, have you solved this already?
I'm looking at the display and I can't see that it would require any software, other than a display driver installed on the computer to work properly.
SOURCE: Monitor resolution not listed, Driver update issue
My compliments. Your description of your problem is great. I know what you've done and I understand your problem.
However, I am wondering about a few things that may help you. the video settings that you are referring to in your description are dictated by the software that drives the video card, not the monitor.
Are you sure you have the latest Manufacturer's drivers for your video card?
I don't see any mention of the video card here.
good luck
tony
SOURCE: LG Monitor only runs in safe mode for computer
You have set the resolution outside the parameters of what the screen can display.
Please give following a try:
http://www.mydigitallife.info/2008/06/22/how-to-change-screen-resolution-and-display-colors-quality-in-safe-mode-of-windows/
SOURCE: Resolution issue with Emachines E211H flat panel monitor
Try to restart ur PC then it will auto detect ur monitor via DVI input. Actually, no driver needed for monitor in now day, they all come with plug and play.
