SOURCE: champion 8500 doesn't have full voltage underload
Sounds like you need a tune up. Check or replace spark plugs, air filter, fuel filter, carberator, and idle linkages.
SOURCE: speed will not kick up when arc is struck
There are CT;s (current transformers) that the transformer output runs through and the AC outlets which sense the current flow and throttle it up from the control board.
Also, Is the throttle linkage free , not jammed up??
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: engine won't run smooth for longer than 5-7 mintues
The throttle control board is not working corrctly
SOURCE: Problems with welding with a Forney 180 amp. Arc Stick Welder
check your input power connections on the primary side of the welders transformer, then if its an infinite control welder check that control,otherwise if it's a plug- in selectable amperage check these connections,it sounds like the infinite control is getting dirty and not passing all the current it shows on the control, also double your O.C.V. on the secondary and see if its with-in welder specs
SOURCE: looking for owners maual for Craftmans industrial ac/arc welder
You can find the manuals for sale for almost all Craftsman units at sears.com and navigate to the craftsman site and then to customer service parts and enter the model number and they will typically show you a parts breakdown of the unit and also offer replacement manuals for sale. Hope This Helps Don
