Will not run because drawer is missing, but drawer will not go back in because the machine appears to be in middle of an action. But we can't reset.
For Jura F7 Series, "Tray Missing, can't put it back in". With a small flashlight, look in to the cavity which the tray and grounds container reside in. Along the right side above a slot to the end, you'll see a white micro switch. with a "Tooth Pick" simply press the switch inward (to the right) and hold till the machine cycles the Levcer / Flap up and out of the way.! Put your tray and grounds container back in and begin brewing!! -dh
Thank you
SOURCE: Jura Capress Impressa E8
Open the drawer and take out the box for the grounds. Run a rinse cycle and it should now go back into place.
SOURCE: Jura Capresso Impressa S9- no steam
Great solution - solved 80% of the problem I had - would also add to check the pressure relief valve (back of pump where water lines to thermo blocks attach). Noticed presure was still low after cleaning solenoid. Ran steam with cover off top (cup warmer plate) and notice water flow in clear line at top (you will see the line). Went to pump, pulled off hose block at back of pump, and popped (carefully) off the black cap which separates the water to the brewer from the steamer. Cleaned this needle and seat, and the spring too, and the pressure now is extremely high at at the steamer wand. 100% fix now.
SOURCE: Where can I find an Jura Capresso Impressa F9 replacement lid
The only sources I have been able to find are in Europe. They do not always wish to ship to the US however. In the US the dealers always want the repair, but seldome wish to sell parts outright. Try this website for parts.
Mike
www.juraprofi.de
SOURCE: Describe your Jura Capresso Impressa E9 Espresso
You can find some detail procedure in this tip below
http://www.fixya.com/support/r5713182-jura_capresso_impressa_f9_malfunction_8
Try it since it have help some other with same problem.
SOURCE: The drawer will not go
You should visual check inside the drawer compartment. There might have some coffee dregs that fall behind the drawer and this is what blocking it to go all the way in. There is a limit switch that is closed only if the drawer is in its place and when this switch is open the machine give the massage "missing drawer" light on. So you use a brush and a vacuum cleaner to clean the drawer depart very good from any coffee remains in order the drawer to sit very good in its place so the limit switch will switch off.
Please dont forget to vote this answer was helpful
Many thanks
