Everything on my Samsung Syncmaster 204bw appears red. How to I return the screen to a "normal" view?
SOURCE: i have samsung syncmaster 204BE monitor. always
If you are talking about the power light flashing and no picture then its not in sleep mode, the power supply has failed. Check our web site at:
HTML clipboard
www.ccl-la.com Look in the monitor repair pages. We have a step by step repair guide for this model Samsung. If you don't want to do the repair yourself we do offer a repair service, information is available on our site.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: Samsung SyncMaster 2233SW Monitor "Not
The "native" resolution of the monitor is the "optimal" resolution -- it looks best to use this resolution.
So, right-mouse click anywhere on your Windows desktop "wallpaper".
Click Properties.
Click Settings.
Move the "Screen Resolution" slider to the recommended settings.
Click Apply.
Click OK.
SOURCE: Shadow on screen
hello
yes this is the problem due to dry sold or bad ic presuent. plz call a hardware engineer to check the problem
thanks
ramesh
SOURCE: My samsung syncmaster 204bw power
Does it do the same with another PC? Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
If it is monitor, then please read below
Look for bad caps first:
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
SOURCE: My Samsung SyncMaster 740N occasionally
This could be because of the 'eco' friendliness of the monitor. Basically a lot of monitors are designed to turn off into a low power state when not in use so to preserve power and life of the monitor. I would return the monitor as the sensors that control this seem to be broken in your monitor.
http://www.fixya.com/support/r7406380-tv_training_manuals
Basic LCD monitor troubleshooting guide:
