Kenmore 53642 / 53644 Side by Side Refrigerator Logo
Robert Clausen Posted on Nov 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Side-by-side kenmore coldspot is warm
Both the refrig and the freezer are warm.  The lights and fans work.  The compressor is hot.  We couldn't find our model Coldspot 59502990 on your list!
Marat Brikov
Level 3:
Director Badge:
Uploaded 100 video answers.
  • Kenmore Master 518 Answers
  • Posted on Nov 26, 2015
Marat Brikov
Kenmore Master
Level 3:
Director Badge:
Answers
518
Questions
0
Helped
324179
Points
3123
Installing Hard start Kit 3n1 Supco.
Daves Appliance Service LLC.
Level 2:
Champion:
  • Expert 210 Answers
  • Posted on Nov 05, 2008
Expert
Level 2:
Champion:
Answers
210
Questions
Helped
77880
Points
369
I would unplug ref. clean the condenser coil, install a 3n1 start relay on the compressor.
1 Related Answer
Anonymous
  • 8 Answers
SOURCE: Warm refrig and freezer
You probably need some refrigerant added. There probably is a leak in the system that caused the lack of refrigerant. Get the leak fixed and add refrigerant before you blow your compressor too. Or get a new fridge.
KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
it should not be the compressor as the bottom is only not cooling.
Both freezer and refrigerator are warm and fan is running and compressor is hot
check model number. if the first 3 numbers are 106. this is a whrilpool made refrig. they have a lot of start kits going bad, It consist of a relay, overload and a relay. you need to replace all three. you can purchase a 3 in1 start kit that will work on all the home refrigs. Check local refrig parts house. usally the small hp kit is fine.
2answers
Freezer quit however fridge appears to be cooling...
if there is a fan in the freezer; in that is not working then yes OR the thermostat has gone. But the unit only has one compressor and if the fridge is working it is normally a good sign.
If you where really concerned you could call a domestic refrig tech they could fix it.
Hope that this helps
Kenmore coldspot model:10653502330 does not stay cold
hi thanks for the question i would check the back by the compressor make sure its clean . then check the fan in freezer to see if it works then see if the frost built up in freezer you could have just a dirty condenser thanks the appliance doc
1helpful
3answers
Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Refrigerator/Freezer not cooling
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, by compressor Make sure compressor is running and not shutting off on overload.. u said comp. hot.. should be warm... Not hot check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
