I too have this problem with my KitchenAid KHHS179LSS-5 model. Based on the owner's manual I located behind the grill which pulled off, the F7 Error code indicates that power to the magnetron was interrupted. You will want to make the following checks: 1. Unplug microwave oven or disconnect power. 2. After 40 seconds, check to see whether this solves the problem. 3. Unplug microwave oven or disconnect power. 4. Check resistance of the magnetron thermostat. 5. Check the magnetron. 6. Check wiring to the 1100W inverter and control system. See "Checking Inverters." 7. Plug in microwave oven or reconnect power. 8. Check operation of all interlock switches. Check door, hinge and cavity front alignment. Adjust as needed. 9. Unplug microwave oven or disconnect power. 10. If switches operate correctly, replace 1100W inverter. 11. If problem persists, replace electronic control. 12. Plug in microwave oven or reconnect power.
After removing the control display, there is a virtual zoo of connectors. So unless you repair microwaves on a regular basis, it may be difficult to ascertain which ones go to the magnetron thermostat. I will probably resport to shelling out the dough to get someone to fix it. Sorry I couldn't be more helpful.
When your microwave oven starts to zap, then
eventually does not heat up, it means there is a problem inside the unit
of the microwave. There are some parts to check inside the microwave
before you can tell the exact component that is faulty and to know if
replacement will do the job for you.
The three (3) main parts to be tested are the power diode, the high voltage capacitor and the magnetron.
But
since all other components are working like the fan, light and clock,
then it is most likely the magnetron. Here is how to test and replace
the magnetron of your microwave. HOW TO TEST THE MAGNETRON Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor. There
are two tests to conduct in order to determine whether or not a
magnetron has become defective. If you receive results other than what
are detailed below, you will have to replace your microwave's magnetron.
Each test is described for you here: TEST 1: Locate your magnetron
and label each of the wires attached to it so that you know which wires
are to be replaced where. Set your ohmmeter to the lowest resistance
scale. Take a resistance measurement between each of the magnetron's
terminals by touching each probe to one terminal each. Reverse the
probes and take a second resistance measurement. Each measurement should
read less than one ohm. TEST 2: Set your ohmmeter to its highest
resistance scale. Touch one of the meter's probes to a magnetron
terminal. Touch the other probe to the metal magnetron housing. Take
special caution to not touch the two probes together. This could result
in an inaccurate reading. This test should produce a reading of infinity
- indicating an open circuit. Magnetron replacement Have a
certified and experienced appliance repair technician examine and
replace your magnetron. This task is much too dangerous for the average
layman to perform on his own.
If everything works, but the microwave oven does not heat, this is commonly caused by a failed magnetron. The magnetron is essentially, the heart of the oven that produces the RF energy that is used to heat your food. In order to replace a defective magnetron, you will need to consider the following: 1. You will need to uninstall the oven from over the range in order to replace the part (you will need to do this anyway, if you decide to buy a replacement oven). 2. Ensure the oven is UNPLUGGED before servicing anything inside the cabinet and remove the exterior case in order to access the magnetron. There are several websites that you can use that illustrate how the oven is assembled: searspartsdirect.compcappliancerepair.comappliancepartspros.com NOTE: If you've never repaired an appliance on your own before, a microwave oven is usually not a recommended appliance to start with. Some models can be rather involved in taking apart. 3. The magnetron replacement part number for the model you have listed is WB27X10305. The average cost is about $80. NOTE: I found the part listed for the best price at appliancepartspros.com at a cost of $76. This model also has a thermostat (bi-metal) that if tripped, will also cause the oven not to heat. The thermostat acts as a fuse if the magnetron overheats. The part number is WB27X10788. You will need to remove the thermostat from the oven and take a resistance check across the component terminals to determine if it is good or not. A low resistance reading indicates a good thermostat. An infinite reading, indicates a blown thermostat and needs to be replaced. The average replacement cost is about $10. Review the parts illustrations at the recommended websites to see if this is something that you may be able easily take apart and reassemble. If you have any questions, please post back and let me know. I hope you find this information helpful. CAUTION: DO NOT operate a microwave oven with the exterior cover off. The voltage inside the High Voltage network where the magnetron is installed can exceed 3,000 volts!
If everything works, but the microwave oven does not heat, this is most commonly caused by a failed magnetron. The magnetron is essentially, the heart of the oven that produces the RF energy that is used to heat your food. In order to replace a defective magnetron, you will need to consider the following: 1. You will need to uninstall the oven from over the range in order to replace the part (you will need to do this anyway, if you decide to buy a replacement oven).
2. Ensure the oven is UNPLUGGED before servicing anything inside the cabinet and remove the exterior case in order to access the magnetron.There are several websites that you can use that illustrate how the oven is assembled: searspartsdirect.compcappliancerepair.comappliancepartspros.com NOTE: If you've never repaired an appliance on your own before, a microwave oven is usually not a recommended appliance to start with. Some models can be rather involved in taking apart. If the model number you posted this question under is correct, the magnetron replacement part number is WB27X10682. NOTE: This model also has two internal thermostats that, if tripped, could give you the same symptoms. The thermostat acts as a fuse if the oven cavity or magnetron overheats. The part numbers are as follows:Cavity Thermostat: WB27X10683Magnetron Thermostat: WB27X10567You will need to remove the thermostat from the oven and take a resistance check across the component terminals to determine if it is good or not. A low resistance reading indicates a good thermostat. An infinite reading, indicates a blown thermostat and needs to be replaced. I would recommend you check both thermostats, first as the replacement cost is much less than the magnetron.
Sabotaged??? What could they mean by that??
It could be a bad control panel or connection, but I would say you have a bad magnetron, the magnetron is mounted loosely, or the RF gasket (mesh washer) on the magnetron is missing, loose or damaged.
I would contact MayTag and see if they have a different authorized servicer in your area, or get on the phone and complain to them in great detail.
Do not put up with this, please.
