SOURCE: bulb removal
All you do is remove the screws from the panel in the back and pull the bulb assembley out.
SOURCE: My Toshiba 51H94 HDTV TheaterWide
Hi
Thanks
for using FixYa. You’ll need to reset it, to reset the TV turn it off and wait
for 5 minutes. After 5 minutes unplug the television power cord from the
electrical outlet and let the television remain without power for more then 1
minute. Plug the power cord back into the electrical outlet. If the television
is plugged into a power surge protector, remove it from there and plug it
directly into the wall outlet. Turn on the television. If the issue is
resolved, then the problem is with the power surge protector and not the
is not resolved then this might have happened due to over-voltage. Please check
the power supply unit for swollen/ bulged capacitors and burnt wires/components
on the power supply board. Please make sure to turn off and
unplug the TV for at least 1 hour (this will drain off current from
all components especially capacitors) before you perform any repairs. Also note
that the TV consists of very high voltages even when it is in off condition.
All this is only recommended if you have electrical expertise and know how to
solder/re-solder components. Please do accept the solution if the issue is
resolved or post a comment for further assistance.
Thanks
Rylee
SOURCE: Describe your Toshiba TheaterWide 52HM84
This happen when you have a bad caps in the power supply 1000UF 25 v. replace it all is about 4.
