Depends on the make and model of your vehicle. in general (most vehicles) there is an adjustment on the steering box. look for a large nute with an allen head set screw in the middle of it, place an allen head wrench on the adjustment screw to ensure it doesnt move and break the set nut free, turn the adjustment screw down one half of a turn and re tighten the set nut. go test drive you car around the block, repeat as necessary. me sure not to over tight/over adjust your steering box, this will cause your car to handle dangerously ans easily loose control. if this process doesnt cure the issue check for a worn rag join and universal joint on the steering pillar. also check for worn out bushings, pitman arms, drag links, track bars and tie rod ends
SOURCE: 1995 dakota loose steering
Have someone shake the wheel while you look under it, while not running. Look for the part that is giving the most movement. Good luck.
SOURCE: 1989 GMC Sierra 3500 loose tilt steering column
Without taking the tilt mechanism off you can only reach 2 of the 3 bolts. If you use 1/4 in. socket on 1/4 in drive with 6 in extension you can just get at the left bolt. If you remove the tilt spring you can get to the bottom bolt. To remoce tilt spring retainer use standard Phillips.
SOURCE: THE POWER STEERING LIGHT KEEPS
This is an issue GM is aware of; therefore, GM has finally issued a recall in 07'. If your vehicle have less than 70,000 mile they're willing to correct the problem. Just take it to an certified GM dealer and notify them.
SOURCE: how do i tighten a loose steering wheel on a 76
there are 3 star bolts for a tilt column. need special tool to remove lock ring on steering lock plate. not easy without it
SOURCE: 1930 Ford Model A coupe Tighten steering
change the bal joints... its not the matter of tightening the bolt..
