Uniden Cordless Phone Logo
Posted on Mar 15, 2012
Ringer is turned off and need to know how to turn it back on?
Phone was working fine and all of a sudden there is no sound when a call is coming in.....we have missed a number of calls. I have looked through the menu on the phone, it will only let me increase the volume level not turn the ringer on or off. so not sure how this happened..and how to fix it.
P Bonner
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Mar 15, 2012
P Bonner
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
3556
Points
31
Look for a "night mode" setting. Won't ring when in night mode
MARCIA WILSON
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 08, 2015
MARCIA WILSON
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
235
Points
THE base of there phone rings. But when the phone itself is in another room, it does not ring. I see no where to turn it back on. No switch
How to turn on my i phone 4 ringer?
go to settings then fine restore factory works.
I think the ringer is off on my NEC Dterm 80 phone. when a call comes in, I hear it ring at my bosses desk but not mine and my line is the main line. How do I turn the ringer back on. Thank you
Ringing is assigned in system programming, so if your phone doesn't ring you can't change that unless you have person on site who works on the system at that level. Some places use the night mode feature to make certain phones ring in day mode, and others to ring in night mode. Not very likely but sometimes the mode gets switched at places who don't realize they have another mode, suddenly only 2 phones ring instead of ...5. Feature,80,Feature, is the code to switch back and forth on a Pro II, an Elite, and an IPK system. This would be done at the reception phone. These phones also work on several other systems so don't know if this works for you. Or maybe you set Do Not Disturb, which would keep your ringer off.
My cordless phone a vtech 5.8GHz The ringer is turned off and I don't know what to do to turn the ringer back on.this is an older phone and i've misplaced my manual.,
Since you neglected to specify the model of your VTech 5.8GHz phone, I can only direct you to enter it into the search box here to download a copy of the manual.
Can't access missed calls, lost my instruction book, need one. Also I get missed calls when I'm sitting right beside the phone. It never rang.Could I talk to someone?
If this is a Panasonic phone connected to a phone system as in an office setting, sounds like the ringer has been turned off. Get someone to call your phone and while they are calling turn the jog dial to turn the ringer back on or use the LCD intertactive keys to turn the ringer back on.
The ringer is off and I don't know hoe to turn it on
I have two uniden phones 2.4 GHz and the ringer is turned off and we cannot figure out how to turn it back on again. Please help!!!
1helpful
2answers
Phone not ringing?
go to settings then phone settings then voice commands then call alert and put ring only
39helpful
2answers
Panasonic cordless phone,
press menu,scroll down to ringer settings,hit select,scroll to ringer volume and hit select then press up the round button in the middle until you hear it make a "ring" sound. adjust your preferred volume and hit save.
30helpful
2answers
Ringer
Hold the Low volume key on the base unit for sometime. A beep will sound that means the ringer of the base unit is off.
2helpful
3answers
How do you turn the ringer back on a V-Teech 5.8 phone
yeah!! i kept playing with my phone that did not have a switch...and i finally got the ringer to come on! the volume up and down arrows are what finally got it to work, i just kept holding it down and it finally responded, try more than once if it doesn't work the first time
10helpful
3answers
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
