Keep getting black screen with error message no bootable device - insert boot disk and press any key ... computer will start in safe mode if i'm quick enough with the f1 key ... HELP
Help please ... can start in safe mode and can actually select "last time computer was working properly"
Re: keep getting black screen with error message no...
Hello good day, just remove your SATA cable from your hard disk if your using a SATA type HARD DISK, change with a new one, or try to pull it back and put it back tightly. It's just a loss contact situation.That's why you are receiving that message.
You hard
drive is missing from the system. Or, just does not recognize it.
The
obvious - Remove any USB devices like drives and any media from disc player.
Its trying to load, but can't find bootable hard drive, CD, or USB...
Remove
the hard drive and reseat (reconnect). Check BIOS by pressing an F key during
boot. Look on the screen for correct Function key. Might be F2 key. Verify
BIOS recognizes the drive. It must be listed! There is no going forward if
it's not. Check boot order and make internal hard drive first. Save and
restart.
If you getting this error then you won't be able to open computer in safe mood, Because this error message indicate that there is no proper bootable media selected or there is no OS in your Hard drive. First thing you can do is go to BIOS and check what is your First boot device selected, if it is other then Hard drive then change it Hard drive and save setting and come out of it. If there is any media, like Pen drive or any CD then remove it and start your computer. If still you have same problem then I am afraid that your OS is Corrupted.
1. Turn the computer on or Restart the computer * Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again. * Ensure that the Safe mode option is selected (the top option) * Press Enter. The computer then begins to start in Safe mode.
2. Do system restore. Follow the steps tp://support.microsoft.com/kb/948247. If it do the same thing go to 3. 3. Recovery.
Actually that error is an indication of some bad sectors on the Hard drive. There is still no guarantee that the recovery will work.
This error message- "No bootable device. Insert boot disk and press any key" means -
The PC cannot see a boot file/disk on either the hard
disk or floppy drive.
Check the floppy drive and remove and floppy disk.
If there was no disk in the floppy drive then it is a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and
re-seat the data cable on the hard drive and also where it connects to the
motherboard disk controller.
If it still gives this error message and the BIOS does not detect the hard
drive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to an
USB hard drive adapter and connect it to a working computer's USB port, if this
computer does not detect it as an external storage device then the hard drive
is faulty.
To get the computer working again, install a new hard drive in your computer
and then install Windows on the new hard drive plus the computer's device
drivers and your programs.
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system. Also this error comes when there is bed indexing unit in hard drive. You can solve this errors with following 2 methods. (1)When you power up the computer press F8 key then enter in safe mode. Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error. (2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk. Boot your computer with that disk For that when you power up the computer press F1 or F2 "del" key to enter in bios. Then go to boot menu and set first boot device as your cd or dvd rom. Then save settings and exit bios. Insert windows disk in cd /dvd rom. Then it boot with that disk.Then you get this message "Press any key to boot from cd.." Then press any key. Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r" Then type "y" Then it fix error on hard drive. Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows. Thanks for using FixYa.
This
FixYa.
For that you need to fix error on harddrive. For that You can solve this errors with following 2 methods. (1)When you power up the computer press F8 key then enter in safe mode. Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error. (2)If
hard drive.For that you need windows disk or recovery disk. Boot your computer with that disk For that when you power up the computer press F1 or F2 "del" key to enter in bios. Then go to boot menu and set frist boot device as your cd or dvd rom. Then save settings and exit bios. Insert windows disk in cd /dvd rom. Then it boot with that disk.Then you get this message "Press any key to boot from cd.." Then press any key. Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r" Then type "y" Then it fix error on hard drive. Then
repairs old windows then it loads again old windows. Let me know if you need further assistance. Thanks for using FixYa.
this time choose "R" option for repair previous windwos " then it
