For the past year my BB 9300 has been syncing with my PC with no problems. All of a sudden the Desktop Manager won't connect. It recognises that there is a device there because (as a test) I selected "forget the device"; then when I closed and opened Desktop Manager is brought up Blackberry 9300 (and my device's PIN) as a heading so I reckon it must "see" the device. What can I do to get it to connect to the device!?
SOURCE: My PC doesn't acknowledge my blackberry storm is
You have to isolate the problem. Please follow the steps below:
1. Connect the Blackberry into different USB port of the computer.
2. Try connecting the phone in to different computer to test if there's really a problem with the phone.
3. Try using different USB cable for the phone.
4. Check the user manual to see if you need to set it as "Mass Storage Device" before connecting it to the computer.
Otherwise, you need to consult the phone manufacturer for some advise.
Have a great day!
SOURCE: not connecting with desktop manager
Download and install the latest Handheld Software for your model then open Desktop Manager and run the application loader once the USB cable is connected to the device. 8220 Software located here https://www.blackberry.com/Downloads/contactFormPreload.do?code=1905AEDAB9BF2477EDC068A355BBA31A&dl=702BB8A8D212AB863750ABA38D5103B0
Just fill out the form and the download is free.
SOURCE: my bb curve 9300 dropped
Try to check the usb slot of your phone,might some corrosion exist,and also try to replace usb cable,might not working properly.check my solution post no.2 on this link,it will give you step by step procedure on how to update or fix your mobile software.
http://www.fixya.com/support/t9692195-phone_cannot_controlled
Thank you for visiting Fixya.
