Running telnet, laser will not work after switching to the second session. laser will only work again after closing telnet and reopening
SOURCE: SYMBOL MC9090 - LASER READER NOT WORKING
You may need to replace the scan engine - I can help you out with this (or any other issues you may be having).
Contact me if you need anything:
Ian
DC Solutions
[email protected]
SOURCE: Cannot read symbologie/BarCode: i25(interleaved 2
You will need to configure the telnet emulator from your pc first and download it to the terminal after.
Check the version of telnet emulator you have. To do this, go to the options menu on the emulator and click on about wavelink.
Register yourself on www.wavelink.com and download the same client version as installed on the terminal. (Don't forget to download the Active sync version.
Tweak all the configuration parameters on the emulator once you have installed it on your pc also enable i2of5 symbology and then download the config only to the terminal.
SOURCE: Hi, I'm writing a php page to be used on the
You need to do something like this...
<script>
function enableScanner(enable)
var objGeneric = new ActiveXObject("SymbolBrowser.Generic");
if (enabled)
objGeneric.InvokeMETAFunction('Scanner', 'enabled'); /* Enables the scanner */
else
objGeneric.InvokeMETAFunction('Scanner', 'disabled'); /* Disables the scanner */
</script>
<input type='text' name='field' onFocus="enableScanner(true)" >
SOURCE: MC9090 being used outside in sunny conditions
If you are using Wavelink TE you can set the screen to different colours. That may help.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
