Question about JVC HD-52G786 52" Rear Projection HDTV
I have a JVC model HD-52G886 tv. that loses sound.
The first time I lost sound I had turned off the tv & went to bed. Got up in the morning & turned on the tv & no sound. I messed with it all day switching audio jacks etc. to no avail. Finally unplugged everything. I then plugged in the satt. receiver only & gave up. Got up in the morning, turned on the tv & it had sound. Picture is good. 1 week later & still only the satt. receiver hooked up I turned off the tv that was working fine went to bed ...got up in the morning turned on the tv & no sound !!! Left the tv off all day. got up in the morning turned on the tv & it's working fine again !!! Any solutions ?
    Top Expert:
  • JVC Master
  • 14,553 Answers
Replace or have replaced the Audio board in the set----a lot of them fail.
Posted on Mar 13, 2012
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 556 Answers
SOURCE: my tv don't have sound', who can help me !
check and see if you have the center channel on in the menu if you do turn it off and also see if you have the internal speakers turned off if so turn them on.
Posted on Sep 15, 2009
BMW Rider
Larry Eastman
  • 232 Answers
SOURCE: jvc hd ila model hd 52g886 red light blinking, and wont turn on
Hi, don`t know if you`ll be able to find this but D9405 a surface mount diode on the main power supply board is a known issue for yours and many other models, it has to be re-soldered not replaced, other joints in area may also need to be "touched up", other than that I had one where connector CN310 was not seated correctly, one side of plug was cocked way up, other than those 2 you may have a bad ballast (board that the lamp is connected to), Be sure that the lamp door is securely closed as they have a switch built into them and if the switch is not closed the set WILL NOT start, hope this helps you out, BMW Rider
Posted on Dec 12, 2007
Anonymous
SOURCE: Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
Posted on May 11, 2008
How do I remove the speaker box from my JVC HD 56G866 tv?
UNPLUG THE TV. then remove the back & you should be able to see up to the speakers.
Jul 23, 2014 | JVC HD-52G886 52" Rear Projection HDTV
I have the JVC 52g886 model and every time i hook high def green, blue, and red cables i have no sound just picture
you need to conect an other lead with red and white ends into tv audio input and the other end into audio out on the equiptment
hope this helps and merry christmas
Dec 05, 2009 | JVC HD-52G886 52" Rear Projection HDTV
My tv don't have sound', who can help me !
Sep 13, 2009 | JVC HD-52G886 52" Rear Projection HDTV
My 52' HD television will not turn on, it is a JVC HD-52G887. The blue light comes on but there is no blinking red light. Please help
unplug the tv, then reinstall the bulb,if that doesnt work youll need a tech to help. (dont buy another jvc tv)
May 19, 2009 | JVC HD-52G886 52" Rear Projection HDTV
How do i reset my jvc tv
Either a bad lamp or bad reciver board.If audio amp ic on reciver board shorts ,it will kill part of supply and lamp ballast will not turn on and fire lamp.
Dec 28, 2008 | JVC HD-52G886 52" Rear Projection HDTV
No sound on my 52in jvc tv
i unplugged my tv and when i turned it back on had picture but no sound and all cards are still in tack.
Jul 31, 2008 | JVC HD-52G886 52" Rear Projection HDTV
Hd 52g886
Your Lamp is burned out.
Sep 04, 2007 | JVC HD-52G886 52" Rear Projection HDTV
JVC HD-52G786 52" Rear Projection HDTV Logo
233 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
