Unplug the microwave and discharge the high voltage capacitor, you will see two wires hooked to the magnetron, unhook one side, set digital meter to ohms "lowest setting" touch the test probs on the two points, if readings are well below 1ohm "usually .1 to .2 the filiment of the magnetron is good, but if no reading, the magnetron is open and there for is bad.
NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitors.
There are two tests to conduct in order to
determine whether or not a magnetron has become defective. If you
receive results other than what are detailed below, you will have to
replace your microwave's magnetron. Each test is described for you here:
TEST 1: Locate your magnetron
and label each of the wires attached to it so that you know which wires
are to be replaced where. Set your ohmmeter to the lowest resistance
scale. Take a resistance measurement between each of the magnetron's
terminals by touching each probe to one terminal each. Reverse the
probes and take a second resistance measurement. Each measurement should
read less than one ohm.
TEST 2: Set your ohmmeter to its
highest resistance scale. Touch one of the meter's probes to a magnetron
terminal. Touch the other probe to the metal magnetron housing. Take
special caution to not touch the two probes together. This could result
in an inaccurate reading. This test should produce a reading of infinity
- indicating an open circuit.
To replace the magnetron
Have a certified and experienced appliance repair technician examine and
replace your magnetron. This task is much too dangerous for the average
layman to perform on his own
Hope this was helpful you.
All the best
Elect_Comp
