Told not getting enough gas to keep pilot lite. Heater is new. Is there some sort of way to trick the unit to stay lite??
SOURCE: pool heater wont fire up
Its just after 1 am here as well, Ontario Canada. Yes, you have to remove the front lower panel by raising it then pulling out at the bottom. Then compare the valve you have with the 2 in the picture on pg 5. If it is easier, you can have your husband call me while doing this and I can talk him through it. My contact information is located on the main page of my company website www.emshvac.com
Thanks
Richard
SOURCE: My raypak rp2100 electronic seems to light the
It is probably something much more simple than that...Turn it on and stand back until it finally ignites, then look, using a mirror, at the burner tray from below. You will probably find a lot of the tubes, especially those near the pilot area, are not working or are burning bright orange. If that is the case, something, probably spiders, are blocking the gas from getting into the tubes. That will cause the big burst at ignition as the gas builds up for a bit before it finally reaches the pilot area.
SOURCE: I have a Raypak pool heater the pilot will lite but the unit will
My Rapak gas pool heater burner will not ignite. I changed the flame sensor and then the main gas valve (on a recommendation of a heating contracter) and after spending almost $300 on parts, I may have not needed, it still will not ignite. The water temp has been around 80 using the solar cover but now with the air temp in the 50's at night and only in the 70's in the day the water is a brisk 70 degrees. We would like run the heater now, so we can use the pool for a bit longer this fall.
Any ideas? Some people told me there is a valve that senses the proper amount of water is flowing around the boiler so it doesn't burn up, is this possiblely the problem that the valve is not opening?
Joe Snyder, Toledo, Ohio
SOURCE: raypak heater. fault cde says (ROL)
Thank you for posting your question here on Fixya.com.
Replacing the roll out switch is an easy do-it-yourself repair. Fixing the problem causing the roll out of the burner flames in the first place is a bit more of a pro job. Something is causing to much heat to roll out the the combustion chamber into the control area causing the switch to fail. You will continue to burn the link until the underlying problem is fixed.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
SOURCE: I have a Raypac digital
Hello my name is Heath it will be my pleasure to assist you. Find the rollout switch and on the back there is a small red button if you push the button in it will reset the switch. The rollout is usually located near the burner section of the heater.I will attach a picture of a rollout switch which shows the small red button.
