SOURCE: washing machine maytag performa
This problem is normally attributed to a combination of two things: A worn out snubber ring, and a worn brake assembly.
The snubber ring assembly is a white teflon ring that sits under the wash tub at the base (called the milk stool, because it looks like an upside down milk stool). The entire wash tub assembly will rest on the snubber as it helps get rid of vibration while the tub agitates and spins. When the snubber starts to wear down, you will notice an increase in tub vibration during the spin cycle and it will sometimes begin to squeak. NOTE: YOU CANNOT OIL THE SNUBBER! DOING SO CAN CAUSE MORE DAMAGE.
The brake assembly is mounted between the pulley wheel and transmission under the washer. As the brake assembly ages, the pad (which is mounted along the rim of a metal disc) begins to glaze over. As it glazes, it will also squeak and cause the sudden "slamming" to a stop. The glazing, coupled with humidity in the air can make this condition worse.
Both problems occur normally with this model washer and can be attributed to normal wear and tear. I recommend replacing the brake assembly and snubber at the same time. You will need, however, a special Maytag brake removal tool and spring removal tool if you decide to attempt this repair yourself (it is possible to accomplish this without the aid of a repairman). Let me know if you need further assistance. CAUTION: THERE IS A 200 LB COMPRESSED SPRING UNDER THE BRAKE HOUSING. ATTEMPTING TO REMOVE THE COVER WITHOUT THE BRAKE REMOVAL TOOL CAN BE DANGEROUS.
SOURCE: MAYTAG WASHING MACHINE
The rubber smell is the belt from the motor to the tub. The grinding sound is/was the tension pulley that keeps the belt tight. The bearing on the pulley probably went out and now the belt is burning because of the friction of sliding around the pulley. The belt and the pulley need to be replaced. If you have the room, turn off and disconnect the hoses. Unplug the electrical cord from the wall outlet. Remove the drain hose and any water in the tub. Carefully tip the washer over backwards, DO DROP IT!!! Now you should be able to see the motor, tub, tension pulley, and belt. With a basic 3/8' drive socket set, probably metric, and a couple of screw drivers you should be able to remove the belt and the pulley. Take the belt, pulley, and model numbers to an applicance parts store and buy replacements.
I only suggest this because I hate paying labor. If you are not machanically inclined then you are going to have to pay the labor.
Good Luck
SOURCE: Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
SOURCE: Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
SOURCE: my maytag bravos quiet series 300 washing machine
i lost the manual , what does "5d" mean when it is
maytag centennial will not cycle through options
