Error message check fan No. 2 on Samsung HL-S5687
SOURCE: Samsung HL-S5679W Check no. 3 fan message
Their is no more you can do.
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee, Wisconsin 53405
(414) 762-8600
Established 1974
SOURCE: HL-S5687 DLp tv
my 56" samsung dlp will turn on and display a picture from anywhere from 30 seconds to 10 min. It will then shut down picture going down first then sound. All 3 display lights will flash and then create a buzzing sound and attempts to turn back on and off but isn't working. I have replaced the lamp but it's still having the same problem. any help????
SOURCE: The screen tells me to check fan no.2 which isn't
you need to have the lamp fan replaced or replace it youself it isn't hard to do.
SOURCE: i replaced the fan # 2 after getting that error on
Which fan did samsung say was fan #2 ? As from my experience dealing with Samsung they dont know the difference between the fans but fan 2 error is usually refering to the fan under the light engine in the L7 and the L6 its the small one in the gray plastic case which blows under the ballast.
SOURCE: how to replace replace fan no.2 on Samsung HL-S4266w? how to re
tack out engine take out lamp take of lamp housing assembly replace fan
