THE DISPLAY SAYS EVERYTHING IS CORRECT,AND I WENT THROUGH THE ITEMS ON THE TROUBLESHOOTING PAGE BUT I GET NO POWER TO THE SPEAKERS. IT WAS WORKING AND I DISCONNECTED THE SPEAKERS, AND WHEN I RECONNECTED IT WOULDN'T WORK. I TRIED ALL THE BUTTONS ETC. STILL NOTHING. THANKS IN ADVANCE FOR ANY HELP, PHIL
SOURCE: Technics SU-G75, No Speaker Output, Headphones
The fact you have output from the headphones is a good sign. It shows the main amp is working fine. However water has clearly got inside something and affected it. The best course of action is to trace back the wires from the headphone socket and see if there is a relay or anything that could get water in it. If you do find something, try applying warm air from a hairdryer. The alternative is to apply a soldering iron to the solder conections of the device. This should get rid of any water inside. If all else fails you might have to replace the relay. But I would try a spray of Servisol first. Just in case some dust has got inside or mineral salt from the water.
Testimonial: "Your instructions worked like a charm, just needed a hair dryer in the right spot. I'm listening to it now! Hooray! Here, I'll turn it up for you..."
