SOURCE: television question
Sometimes on the Symphonic tv's you can activate the game mode by using the channel button and depressing it to channel 2 an then increment it (channel down) one click it will go into the aux or game mode. this does not work on all symphonics. It's just a method of default. If this solution, does not work , you can go online the Tritronic.com site or even the symphonic site and order the correct rem ote. It will cost you about $30 dollars or less. Also there is a company that sells replacement remotes called Motiva. They are and exact clone but only cost $10.00. Scrivitron
SOURCE: No remote, need code for universal remote
Try this method:
Turn on the device you want to program.
Press and hold CODE SEARCH until the indicator light lights then release code search.
Press and release the device button you are programing TV, the indicator light will blink once then remain lit.
Press and release OFF/ON until your device turn off.
you may have to press upto 200 times
When your device turn off press enter button the indicator light will go off,good luck.
SOURCE: remote codes
URC-3220 One for All Big Easy 3 Universal Remote
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Symphonic TV & Scientific Atlanta Explorer 2000 cable box.
Please review my Fixya Tip posts for:
I hope that helps.
