Black and White pictures on all modes? Main board (main board send the serial clor and sybc singnals to the T-CON or the T-CON (T-CON (Timing Control) decodes the serial siganls to drive the Gate and Source of the TFT on the LCD screen) from my experience.
What do you mean the colors of the wires when the oxygen sensitive type NTK NO. (39210 - 23700)
Which means : signal,heater +,heater - , ....
the clor wire is :BLACK.WHITE,GREY,YELLOW AND BLUU
THANKS
i would assume the red crt is bad or the red video amp is bad I would also assume you tried turning up the clor in the menu?? if it is the ube i would say no not worth fixing
i think you are they should be color coded and match up directly .....however if you changed the wires completely they i would suggest find another 2003 Impala and either photograph it or write the sequence down a dealership will allow you to look at the motor even if you have to pretend you want to test drive it or just look it over
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
