My nokia 5310 screen goes blank when i turn on my phone it's blank screen Someone--Help me plz.........
SOURCE: nokia 5130: blank screen, phone doesn't turn on
That means your phone got a corrupted software installed to its memory. A hard phone reset can solve this problem. Typically a nokia symbian series phone can be formatted using this code *#7370# then the default key is 12345.
Hope this could help.
Testimonial: "yes, it did get corrupted by a software and I had to give it to some workers at nokia to fix it, I lost the info on the phone (except memory card)"
SOURCE: 5310 blank screen
Check if your memory card is corrupted or damaged or the firmware is also damaged and needs to be reinstalled.
I advise that you visit a nokia store and get your phone checked up.
SOURCE: The backlight on my Nokia 5310 does not work at
your phones LCD ,the glass screen is damage...unfotunately it cannot be repaired because once its broken it was disposable...you still use the phone in calling only and but you did know who is the one who calls you..in our cuntry ,5310 LCD worth 1,500 pesos or around 50 dollars...but there is cheaper ,the 2nd hand LCD comes from unit that software is corrupted or the other parts is defective but the glass screen is still good..i hope it will help you ,thanks for trusting fixya ...
br,
fullbar_28
SOURCE: Nokia 5200 goes on Blank screen
it's a software problem of ur phone u need to reinstall ur mobile software...then it will work
SOURCE: My Nokia 5310 screen turns white, and then phone
you have to slash your phone .that is reset your phone settings and reinstall phone softwares which can be done by a technician.
screen goes bank
