ERROR REPLACE TONER
This came from the Brother HelpDesk, yes they rang me and it worked.
Cover open
Press Clear
"Replace Drum?" (ignore this and quickly...)
Press Start (blank screen, quickly...)
Press Up arrows then switch to down arrow to 00
Press OK
tks for your help I was pulling out what little hair i,ve got,it worked a treat
Its excellent. working. Thanks
ITS WORKING DEAR THANKS
Thanks it worked...
its working but this problem agin and not this work what is solution please help me
How to reset brother dcp-7055 multifuntion printer machine
My dcp-7055 given the message Toner low after i filled it by technicians so what i do plz tell me some thing.
[email protected]
Paterpaper's
solution worked for me after a couple of attempts,and a failed call to brother helpline,I wish that brother's helpline were aware of this fix
My dcp-7055 given the message Print Unable EF, after i turned the power on so what i do plz tell me some thing.
[email protected]
DCP- 7055 Print Unable EF Problem
SOURCE: brother dcp 7020 says toner end life
unplug plug it back in, did you remove the protective cover and clean coria wire?
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_018.html?reg=us&c=us&lang=en&prod=dcp7020_us
SOURCE: Brother printer dcp-330c error 46
press "menu" "black start" and "up arrow 4 times". that gets you into maint. mode to be able to reset purge counter. next enter code "80" by pressing up/down arrows and pressing "ok". press "black start" several times until you see "purge count". now press "2783" and "ok" to reset purge count. then press "black start" about three more times or until you see flushing count. again, press "2783" and "ok" to reset. now hit "stop/clear" a couple of times and press "99" to exit or use arrows to get to "99" . at this point, you may have to press "ok" to get out of maint. mode, but i think once you press 99 it backs out automatically. next time this comes up however, you will need to have your ink absorber box and flushing box replaced.
hth,
razors
SOURCE: i have a printer dcp 7030 brother company i am
i have a printer dcp 7030 brother company i am showing problem toner life end after reffling
SOURCE: i have dcp-7030 brother printer.
I know how to solve drum end problem along with change tonner.... Send me mail on [email protected]... Thanks
this worked for me after a couple of attempts,and a fruitless call to the brother help line,I wish that all at brother help were aware of this fix
