Sharp LC32D62U 32 in. LCD HDTV Logo
Anonymous Posted on Mar 09, 2012
Sharp aquos getting only audio and blue screen for video :( i have done all troubleshooting steps and now just want to buy the board needed. all caps are looking ok tried the reset. tv just turns itself on when i plug it in dont have the remote so no clue if menu shows up. backlight apears to be working and when i hook up xbox 360 i can hear it boot and see the screen get brighter (not much) thanks for your help
  • Anonymous Mar 12, 2012
    thanks for all the replys i am new here and waited a few days and took the lcd apart and selling boards on ebay :) thanks eveyone for your replys
Level 3:
Top Expert:
  • Sharp Master 76,851 Answers
  • Posted on Mar 10, 2012
Sharp Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007550
Points
237762
Hello
Digital video processing stage on the main board is faulty. The main board mey need repacement
5 Related Answers
Anonymous
  • 53 Answers
  • Posted on Mar 14, 2008
SOURCE: images go suddenly darker
Turn off the the OPC feature in the Menu. If that doesnt help, what youre seeing is most likely the Advanced Dynamic Contrast going to work. In layman's terms, it automatically adjusts the contrast depending on the video signal it is receiving. If you want to disable this, change the AV settings to "User" (button underneath the bottom door on the sharp remote)
Anonymous
  • Posted on Jul 01, 2009
SOURCE: Aquos screen blacks out with xbox 360 using Component Cables
Downloaded the updated firmware from the sharp website to a usb drive. Placed the drive in the TV and went to the update software option on the TV menu. Since the update, I no longer get the black-outs on the screen. I also put the resolution on the 360 back up to 1080p and it works great, even through the component cables.
Scoee Scoffer
  • 162 Answers
  • Posted on Jan 15, 2010
SOURCE: green pixels on dark picture areas on Sharp Aquos.
This may help, but at your own peril.
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Anonymous
  • 490 Answers
  • Posted on Oct 14, 2010
SOURCE: how do i hook up
You have a few options actually. depending on which 360 you have you have at least 3 ways to connect; 4 if you have CDMI cable output on Elite 360. you only need to pick one though. easiest is the plug with one yellow and a red and white. the yellow is the video and the red and white are the left and right audio. You can use the red green blue plugs choice if your tv has that input. in that case the red green blue are the video and you use the other paired red white for audio. You can use the S video connection (the round one that looks like a mouse plug) for video. You can use the HDMI (flat, looks like giant USB slot) for really high quality video. So, basically just use whatever cable you happen to have. If you still have questions, please ask as we will definitely get you hooked up for sure:) farmerbear at FixYa
Anonymous
  • 23 Answers
  • Posted on Jun 10, 2011
SOURCE: The demo mode apears every
I'm not certain of the specific model number of your set, but this should be the same for all Sharp Aquos models.
First, navigate to TV input, and select menu
Next, enter setup and select, "ez setup"
In the ez setup menu, select "home", not "store", for television location.
This should turn off the demo mode and solve your issue.
I have s Sharp Aquos tv. Screen blank on Hd
It sounds like there may be an issue with the HDMI input on your Sharp Aquos TV. If you are only experiencing the issue on high definition channels, it is possible that the HDMI input is not able to support the higher resolution of HD channels. To troubleshoot the issue, you can try using a different HDMI cable or a different HDMI port on the TV. If the issue persists, it is possible that the HDMI input on the TV is faulty and will need to be repaired or replaced. I would recommend contacting Sharp customer support for assistance with this issue. They may be able to provide further troubleshooting steps or assistance with repairing the TV.
Sharp aquos troubleshooting
i have a sharp aquos model lc-62c42u. when i power it on works great for about a minute. after that my screen has blue fuzzie lines with the picture still in the background. Ive already tried the INIT reset along with the K. is there any type of schematic I'm able to find on troubleshooting the power supply board.?
My Sharp Aquos lc-46d62u has audio but not video. Only a blue screen
If you are using a box of some kind remove it and the set from power for a while and then plug back to allow both to come on and reboot---blue screen usually means no signal seen..........check the other inputs on set with a dvd player etc.
I'v got a sharp aquos and the blu-ray dont work on it the dvd's work? and dont no where to get it fixed can you help please?
The Sharp is not getting the go codes from the blue ray, or the blue ray is not sending them. Sony has a cool comcept to force you into buying Sony stuff. HDMI sends information down the cable that is caring the audio and video that tells the Sharp that its OK to allow the signal in. Some receivers, and or DAs do not pass this data, so the TV will not display the video and audio. Connect the blue ray player directly to the TV, and loop audio out to the receiver for the auio, and see whay happens.
1helpful
Sharp Aquos LC C3234U screen goes black, audio is still good, turn to another channel far away from the intended channel & it will reset. More often as time goes on.
Ur LCD inverter board it dead,replaced this LCD inverter board will get ur picture back.It long board in shape.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.
Sharp AQUOS LC-26SH10U 26 inch LCD Television. Video input problems? No audio. I get a picture using RCA cables but nothing using coax cable. Also I have no audio. When I get a picture using the RCA cables...
You need to replace Main Board of TV to fix its issues, click Shop Jimmy to see an image of that board, call Shop Jimmy on 952-881-6492 or 877-881-6492 for main board availability as currently its out of stock.
Thanks.
Sharp aquos 32 inch lcd. suddenly only audio,, no pic (blue and now black screen)? is this normal failure - repair said new panel required but cost same as a new lcd - BER - 3 months out of warrenty. HELP...
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
It sure sounds like the tech is too lazy to do some troubleshooting. These two parts are the most common things that go bad. It is easy to collect the money by giving high estimate for repair. It give us the repair guys the bad name.
Please post back what you find.
A Sharpe Auquos LCD TV THE SCREEN IS ALL COLORED LINES LIKE A TEST PATTERN ,YOU CAN SEE A THIN LINE IN THE MIDDLE OF THE SCREEN THAT APPEARS TO BE THE PICTURE SHRUNKEN DOWN TO THIS LINE ,I replaced the LCD...
Hello!
Here you can find a llist of manuals to Sharp Aquos TV's.
Hope you'll find the one you need (or a very similar one) and the "Troubleshooting" part will help you!
aquos
1helpful
No Video on Sharp Aquos LC-46D62U
Have you check all inputs as the HDMI inputs and the composit inputs are processed on a different bd?
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
