The HP Probook 4530 will not boot. The light above where the power cord is inserted is blinking amber and white. I have tried removing the battery but that has made no difference. One time it started to boot but then quit. Help...
The power supply is the issue, or the DC jack in the laptop has developed bad connections, or ram issue. Remove 1 stick of ram and power on, if no! remove second one, and replace the first, power up, if no! test the power supply for proper voltage, if okay! it is a DC jack or motherboard problem.
SOURCE: hp probook 4530 ac connected indicator flashing. will not power up
Either your charger is not providing the perfect voltage or there is a short circuit in your motherboard. Try replacing the charger first. If still the problem persists then you should check the connector. try resoldering it cause loose connection in it also sometimes causes this problem.or you need to change the motherboard finally.
SOURCE: HP ProBook 4530s don't start. Lights blinking!!!
Sub out the ram one at a time, if luck is there unit will start, second option is remove the main battery often loads the system down.
When you plug in the power cord is there any lights
whatsoever on the laptop, where the plug goes in or on the AC Adapter of the
power cord?
When you press the power button do you hear fans running, hard drive spinning,
lights on the computer, hear any beeps or lights constantly blinking, hear the
DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a
second or two? If so the laptop is trying to boot or may have booted, but
the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the
laptop and why it is not booting. Most times it's a motherboard issue
when you hear beeps or blinking lights continuous. Most times the problem
is with the memory or Video Card. Count the Blinking Lights or Beeps and take
note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever
when you press the power button. And if that's true maybe you was
operating off the battery the last time you had it on and since the power cord
is bad, it was not charging the battery so the battery is drained and the power
cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the
Battery, then Press and Hold the power button for 30
seconds. After 30 seconds plug the power cord back in (leave the battery
out) and hit the power button to see if it boots. If it does, you can put
the battery back in and let it charge.
Maybe your DC Power Jack which is where the power cord plugs
into the computer is bad. Take an ink pen and push the tip inside the
jack and see if the little pin wiggles, if so the jack is bad. You'll have to
take the laptop apart to fix it. Most times it is soldered onto the
motherboard, so you will have to desolder the old and solder a new one.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Remove the Battery, Remove
the cover that houses the memory on the bottom of the laptop then remove
one of the
memory chips. Set the chip aside then try rebooting the computer.
If it boots, then you know the memory chip you set aside is bad so mark
an x on
it with an ink pen. If it fails to boot then move the chip to the next
memory slot and try rebooting. If it fails take the chip out and set it
aside, then put the other chip in and try booting it in both slots. If
it
boots, just to verify that the chip set aside is bad, mark an x on it
and put
it into the open memory chip slot and try booting.
I don't think it is related to the power supply or jack connection because the amber/white blink occurs when just the battery is inserted (no power cord).
I'll give the ram a try.
No luck on any front (although I do not have any RAM to sub out. It's under warranty so I'm calling HP. Thanks all for the help.
I have a same problem on HP G42t-200. when bettery is in amber light blinks, when only ac adpt in white light stay on but when I press power button, the light blinks from white to amber and after a few seconds the light stay white again.
tripping off when booting
