Official Brand Answer
- Posted on Mar 13, 2012
Re: Printer did not turn on
If you are encountering power problems with your printer, please
go through the following checklist:
- Make sure the power cord is
plugged in securely and directly to the power outlet. Power surge
protectors can draw power away from the printer.
- Disconnect the power cord from
the power outlet and the back of the printer and then reconnect it.
- Check the power supply box (if
there is one) to see if it is warm or cold, as there could be a defective
power supply issue.
- If there is access to a
voltmeter, test the power supply to ensure that it registering the correct
amount of voltage (most Lexmark printers have a 30Volt output).
- Make sure the correct power
supply is connected to the printer.
