Xerox Phaser® 8550, 8560, 8560MFP Extended Capacity Maintenance Kit, 30,000 Yield, Part Number 108R0... Maintenance / Upgrade Kit Logo
Anonymous Posted on Mar 09, 2012
Driver I cannot find the driver to change the default to black & white.
elig1000
Level 2:
  • Expert 112 Answers
  • Posted on Oct 16, 2013
elig1000
Expert
Level 2:
Answers
112
Questions
0
Helped
45111
Points
257
I would try to download a new driver from the Xerox website and set that one to default.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Set xerox 7845 to black as default print color
You can always look for answers to your Xerox questions at www.xerox.com/support .
Default the Print Driver to Print in Black and White Only for a Microsoft Windows 7 OS:
The steps below can be used to restrict color printing through the print driver.
NOTE: This solution requires administrative permissions and may require the assistance of a System Administrator.
Open the Printers, Printers and Faxes, or Devices and Printers window. See the Related Items below for additional information.
Right-click on the printer, and then select [Properties] or [Printer Properties].
Click on the [Administration] tab.
Expand the [Configurations] section.
Enable the option for [Black and White ONLY].
Click [OK]. The driver will now have Black and White printing as the default and locked so that the option cannot be changed.
Default the Print Driver to Black and White for a Microsoft Windows OS:
Open the Printers window on the computer.
Right-click on the required printer, and then select [Properties] or [Printer Properties] depending on which operating system is being used.
Click on [Advanced], and select [Printing Defaults].
Click on the [Image Options] tab.
Under Color Correction, select [Xerox Black and White Conversion].
Select any other required driver default settings.
Click on [Apply].
Click [OK] to save the settings.
Close the window.
Default the Print Driver to Black and White for MAC OS:
Launch an application, preferably not your browser, that you can print from, e.g. Microsoft Word
  1. Select File -> Print
    1. Select Xerox Features where it says Copies \& Pages
    2. Select Color Options from the drop down labeled Paper/Output
    3. Select Black and White (Black and white printing on the Xerox 7845 costs less.)
    4. On the Presets drop down, select Save As and enter a name, e.g. "Black and White" if you print to multiple printers, check the All Printers
    5. Click OK to save this preset
Now you can test printing by clicking Ok to the print dialog.
1helpful
The priter goes through the motion as always for printing but a blank piece of paper comes out. I have cleaned the print head but It still does the same thing. Do you have any suggestions that I might...
If you are printing using a color (not "black cartridge only" ) driver, yes, the printer won't print because it uses a "process black" when you use a color driver.
In other words it creates black using the 3 colors, and doesn't actually touch the black cartridge.
You will need to change the default driver to one that you create.
go into control panel, hardware and sound, devices and printers (win7)
right click the officejet 6500 (not the fax driver) and click printer properties
click the advanced tab, and click printing defaults
click the fast economical printing template.
Change "print in gray scale" to Black Ink Only
Click "save as" and name the profile "black draft"
click the newly created "black draft" profile, and click APPLY and OK
This will now be your default, and it will print in black and white while the color cartridges are empty.
2answers
How can I get my HP 6500a plus printer to PERMANENTLY default to black printing? I am needlessly using too much color and the default setting is only for a single document.
Hi
Go to right click at the printer icon on your computer and choose printer properties or printing preferences and from there choose the color setting to print in black alone. Regards
Is there a way for me to set my copier to default print black and white? I know this can be managed by each PC but sometime folks forget so i would like to deafult all print jobs to B/W unless otherwise...
TO SET THE MACHINE FOR BLACK AND WHITE ALLL YOU NEED TO DO IS SELECT BLACK ON THE COPIER PRESS THE UTILITY USER KEY THEN PRESS COPIER BUTTON DEFAULT BUTTON THEN SELECT CUREENT SETTING
THIS WILL DEFAULT THE MACHINE TO COPY IN BLACK TO SET PRINTING IN BLACK YOU CAN SET UP THE DRIVER TO PRINT IN BLACK ONLY
1helpful
My color laserjet 2025 won't print color
If you print the demo page from the menus is that in color? If it is then it is possible that you have a black and white only printer driver installed or your driver is defaulted to black and white only. It is also possible that you have one color empty which stops color printing but often allows black and white printing to continue.
I just got a 8560MFP and I am running win 7 64. I can not get the printer to print in colour only black and white, and advise/help?
in your printer driver, Start/printers & Faxes.. Right click the printer Icon for your 8560 and goto properties.
Goto Advanced Tab and then Printing Defaults..
Make sure the Black & White printing is Unchecked.
Phaser 7760 only prints using black toner (no C, M or Y)
did you try adjusting the settings on the printer driver itself as in go to printers and faxes....right click on the printer and left click properties........under the advanced tab choose printing defaults and change the settings on the printer driver
Cannot get to print in color. everything is black
Print out a test print to see what comes out. If the printer is printing the colour blocks then the printer should be OK. If not then check the colour inks to make sure they are OK. Then run a full cleaning cycle and reprint the test sheet. Keep doing this until the inks are printing OK then run an alignment test and adjust as necessary. Next check the settings of the print driver to make sure that you have not defaulted to Black & White or Greyscale printing only. Also check the printer to make sure that the setup is OK and no defaults to Black & White / Greyscale printing have been set. If all this is OK then the most likely culprits will be the interface lead to the PC / Mac. Check that this is inserted and secured correctly at each end and is not damaged. If this is OK then uninstall the printer driver and download and install the latest printer driver from HP support at the following link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=61236&lc=en&cc=uk&dlc=en&lang=en&cc=uk
Simply choose your operating system to proceed.
Once installed reboot the PC / Mac and all should be OK.
Wont print 2 colors, only black and white
The print driver might be defaulted to black and white. Change it to color.
Black printing morphs into red after black ink cartridge installation
Your printer creates it's black by using ALL the colours together. This effectively gives a very dark purple rather than black.
It sounds like you have a colour cart that is drying up or may be struggling to get enough air into the cartridge. Make sure you have removed any tape over the vent holes if you are using compatible inks. If not then try running a couple cleaning cycles via the button panel/driver.
If you alter the settings in the driver by going into START - PRINTERS AND FAXES and then right click on your 2610 and select PROPERTIES - the changes you make in here will be set as the default settings for each print job.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
