Leviton  Decora Light Dimmer Switch Logo
Posted on Nov 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Leviton slide dimmer switch w/locator light light comes on but doesnt dim
I just bought this dimmer switch today and installed it- its in the dining rm, a 3 way switch on one side and this dimmer switch on the other side- connected to a dining rm light, both switches turn it on and off, but it will not dim, just flickers a little when the dimmer is slid
ashburton
Level 3:
  • Master 417 Answers
  • Posted on Nov 03, 2008
ashburton
Master
Level 3:
Answers
417
Questions
0
Helped
179408
Points
1232
What sort of light is it , dimmer switches normally only work on Incandescent type lights not flourescent type.
Otherwise it sounds as if the dimmer function is faulty.
2answers
Installed Leviton Decora Slide Dimmer switch 6672 and moving the slide turns on the lights but I have no dimming action ?? Using dimmable LED light bulbs I replaced a regular Leviton switch.
https://www.leviton.com/en/products/6672-1lw
Specs say Dimmable LED lights are fine, so that means your lights are the ones at fault. Although marked dimmable, they are aren't. Swap the bulbs out for another make. Also if you read the FAQ on the lower section of the page, there are secret switches hidden behind the slider. Also interesting to me is that on the top metal fixing plate it shows
LIGHTED OPTION
ON - OFF
Dimmer slide does not dim
Replace it. They fail and and that is not uncommon. good luck
We have Leviton push button slide dimmers w/the locate lights for power outlets and lights throughout our house. A couple of months ago one stopped working...you push the button to turn it on and it...
Wiring is not best suspect.
If all the Leviton devices were installed same time, they may be failing at same time due to lifespan.
For example, ordinary on-off switch is a mechanical device with mechanical parts, and mechanical switches last many years longer than wiring devices that have electronic parts.
Electronic devices usually have standard 1 year limited warranty.
http://www.leviton.com/OA_HTML/ibeCZzpHome.jsp?minisite=10025&respid=22372
Needed to turn another circuit off to change a bathroom light fixture. In the process of finding the correct breaker for this project, another circuit was tripped for my dining room where there is a...
Just tripping the breaker should no affect your dimmer unless maybe malfunctioning or wired incorrectly or loose connection. It is hard to wire incorrectly, for there should only be two wires attached to the dimmer? Replace dimmer and make sure wiring is correct if not sure about wiring yourself contact local electrician for your safety. There are very good instructions inside the switch packages, make sure to buy a quality switch, Leviton is a good name I would lean towards faulty switch or loose connection but I'm not there. Good Luck Karen....
Apr 20, 2011 • Home
Changed out 3-way switch with 6633-p and it will not operate light. this is a 2 location 3-way being used on a dining room chandelier.
Look at 3-way drawing in 6633 manual.
Notice that device has to be installed to Hot wire.
Only one of your 3-way switches will have the Hot wire.
Change device with other 3-way switch.
Make careful note of which wire connects to dark-colored screw. This is the common screw.
My rotary dimmer doesn't switch 3-ways. I have to push the dimmer button to "on", then I can use the other switch to turn on/off.
You posted under Leviton rotary dimmer.
Lutron and Leviton have many 3-way dimmer styles, and both make 3-way rotary dimmers.
I remember years ago replacing 3-way switches with dimmers and having same experience as you. One dimmer has to be ON for the other dimmer to dim.
Later I learned when you replace both 3-way switches with dimmers, you buy a control-and-companion dimmer set. One dimmer is main, and it lets you dim from both locations. The two dimmers communicate with each other electronically. Buy these dimmers at lighting store that specializes in fixtures and dimmers. Ask for most experienced salesperson.
I checked to see if rotary dimmers are made in the companion set. And neither Leviton or Lutron show 3-way companion set rotary dimmers.
1) Leviton spec sheet on rotary 3-way dimmers does not show companion dimmer. This indicates that Leviton rotary dimmers don't have capability of communicating with each other.
2) Lutron has image of 3-way rotary dimmers.
Image shows single rotary dimmer in 3-way & 4-way circuit.
This tells me that Lutron does not have companion dimmer for 3-way rotary dimmer.
2answers
Newly installed Leviton dimmer switch humming at the switch
Unfortunately, the hum is normal for operation of that type of dimmer at low levels.  Sometimes the lamp filaments will also "sing" a high pitched sound.
Top Leviton Electrical Supplies Experts
john h
Sean Wright
Sean Wright
CJ Rock
CJ Rock
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
