Question about Sony VPL CS5 Multimedia Projector
My Sony VPL-CS5 has a double image
I bought it used and it works fine except the fact that there is a double image. It doesn't matter what i have hooked up to it or if i have nothing hooked up to it. The menu is a double image as well.
5 Suggested Answers
Anonymous
SOURCE:
Anonymous
SOURCE: Sony VPL CS5 Multimedia Projector Problem
The Temp/fan light is on and is shutting down the projector what do I do
Posted on May 07, 2008
Anonymous
  • 115 Answers
SOURCE: Sony VPL-CS5 menu will not display
Give input signal to the projector and see that if the menu appears or not on the screen.
if menu comes on the screen then put the backgroung color to blue, instaed of black.
if nothing comes on the screen, then the LCD panels are faulty.
Viren
RAVE SERVICES
Posted on Mar 04, 2009
stephandgi
SOURCE: VPL-CS5 no power indicator
no power and after some months the power indicator comes on
Posted on Dec 31, 2010
raj somaiya
  • 5370 Answers
SOURCE: vpl-cs5 projector starts then shuts
The internal fan ,that are to be checked.The fan should run.If the fan is not running then projector will turn on,then start but will shut off.This happens because the internal lamp housing and board.This two things gets overheated,as soon as you turn on the projector.So this fan this there inside to cool the lamp housing and the board.But if fan is either slow or not running then internal heat temperature increases and unit shuts off.Its common problem,this is to save internal board and lamp housing from getting overheated and short.In this case take the unit apart from its back,by re,moving the screws,then see the fan,if its very dirty then it has to be cleaned by the cleaning brush then check the fan wiring.If its ok,turn the unit on and see.If the fan is not at all running then its faulty fan,but if the fan is running but very slow then from the back apply any external table fan too,to the unit and then turn on the unit.In some cases,not in all.In some cases this has helped to make the projector work.In other cases the fan has to be replaced.------------ Also as you mentioned that Air filter is clean,still try cleaning the filter once before replacing the fan. To clean the air filter please perform the following steps: 1. Switch of the Projector and let it cool down 2. Disconnect the Projector from AC. 3. Remove the air filter cover. 4. Remove the air filter from the cover. 5. Wash the air filter with a mild detergent solution and dry it in a shaded place. 6. Reassemble the filter and the filter Cover. ----------- this should help.Thanks.Helpmech.
Posted on Jan 26, 2011
Sony vpl cs5
Original lamp for cs5 USD100
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Jan 16, 2014 | Sony Lamp Module for Sony VPL-CS5/CX5...
Sony VPL-CS5
you must change the lens. the cost is high. see the sony site for replace the parts.
Sergio
Mar 27, 2008 | Sony VPL CS5 Multimedia Projector
I have a sony vpl-cs5 but is not turn in on, some body can help me, have a blinking led that say lap/cover.???
That could indicate the following-
1. The lamp cover or filter cover aren't properly closed. Try shutting the projector down> opening both covers> closing them> restart
2. The lamp is nearing the end of its life or is faulty and you'll need to replace it.
May 04, 2011 | Sony VPL CS5 Multimedia Projector
Sony vpl cs5 projector will not turn on now power what so ever... Fuse on main power board is fine and power is getting to the main board at the back of the projector (the board which runs the bulb) the...
Have you tried the following:
Connect the power cord and turn the projector to standby mode.
Press the following keys on the remote commander in the following order for
less than five seconds each: RESET, <,>, ENTER.
Feb 26, 2011 | Sony VPL CS5 Multimedia Projector
DIRTY LAMP FOR VPL-CS5 SONY PROJECTOR (USED)
to clean the lamp: no chemicals, nothing abrasive. you can touch the outer glass (not with your fingers), but do not touch anythjing inside the bell. best thing to use is a microfiber cloth. your lamp is nearing or has passed 2000 hours of use. the projector is telling you to replace it before it blows (and sometimes shatters). after you replace it, reset the lamp timer (through the menu).
Dec 17, 2009 | Sony VPL CS5 Multimedia Projector
Viren
RAVE SERVICES
Mar 04, 2009 | Sony VPL CS5 Multimedia Projector
Lamp time resetting
HI
Not sure if its in the handbook but you can download a copy from here
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/VPL-CS5-_E
Feb 21, 2009 | Sony VPL CS5 Multimedia Projector
Sony VPL CS5
You need to clean the filter , the unit is shutting down so it doesnt over heat..look for online manual on how to remove filter and blow off dust.. Good Luck
Jun 30, 2008 | Sony VPL CS5 Multimedia Projector
It just wont turn on
Pls open the Lamp unit and check it if it is giving the power indication on the panel.
Viren
Nov 17, 2007 | Sony VPL CS5 Multimedia Projector
probably the lamp could be failing
or check the fan'lamp cover switches are being 'made'
Oct 17, 2007 | Sony VPL CS5 Multimedia Projector
Sony VPL CS5 Multimedia Projector Logo
Top Sony Office Equipment & Supplies Experts
jasbo
jasbo
Eric Rotmil
Eric Rotmil
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
