Hi just got watch in mail. The second hand is pointing to 12 and doesnt move. I have wound the watch up and the minute and hour hand are moving
SOURCE: Stop watch hand
You have to reset your watch. Pull out crown to first click and try to move stop watch hand by pressing one of the pushbuttons. If this do not work, push the crown back in. Now pull out crown fully tto the second click and try to manipulate with pushbuttons again.
After resetting stop watch hand to 0 push the crown in completely.
Job done.
SOURCE: WATCH RUNNING TOO FAST BUT NOT THE SAME IN SAME INTERVALS
i think it has prob with its balancer.. anyway.. in this world there is no constant time,, n,n
SOURCE: Hands of watch out of synch
My watch just did the same thing. I unscrewd the back off as to change the battery then the pulled up gently on the insides (on the opposite side of the time ajusting knob) just enough to allow a staight pin to slip between the glass then I advanced the adjusting knob while holding back the hour hand untill it was properly aligned.
SOURCE: After a drop from 1 meter height, hour hand
could be following Issue
1, Hands out of alignment & blocking each other
2, Marker on dial fell & stoping watch hands motion
3, Gear train setting disturb or Gear tooth break
hope this help
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
SOURCE: watch hour and minute hands are not lined up at 12 o'clock
Take the back off, then slip the works out of the case. move the hands to line up at 12.. hope this helps..
When I start the stop watch the second hand does not move
