Cell Phones Logo
Anonymous Posted on Mar 07, 2012
Mxit evo pc
Please help, mxit gives me errors when i try logging in yet prior to this i had no issues: Problem Event Name: CLR20r3 Problem Signature 01: mxit evo.exe Problem Signature 02: 2.1.0.0 Problem Signature 03: 4e64848e Problem Signature 04: System.Xml Problem Signature 05: 4.0.0.0 Problem Signature 06: 4d92f388
Anonymous
Level 2:
Sergeant:
  • Expert 192 Answers
  • Posted on Mar 07, 2012
Anonymous
Expert
Level 2:
Sergeant:
Answers
192
Questions
0
Helped
41937
Points
607
HiYou need to delete mxit and re install..You can get the setup from www.getjar.com
Hope this helpsRegards
Testimonial: "i have done this several times, still no luck . . . your feedback is appreciated however, than you"
12helpful
I would like to download mxit to my acer laptop and i dont know how to
Hi!
If you would like to download MXit for laptop, you may click on the below. It is the direct link for download of MXit specially designed to work with laptops and desktops.
http://evo.mxit.com/pc/setup.exe
Hope this helps and thanks for reading mu suggestion.
2helpful
Someone logged in my mxit and change my log in name and pasword. how can i get it back plz. my nr. is 0848127797. reply on 0848127797
Sm1 log in wit ma acount bt when i try 2 use it it tels me tht ma pin its invalid plz help me plz ma mxit name its kinetic deep ma mxit id its 0799045605 plz reset ma pin n gv me new 1 ma number its 0843298958 tnx alot
I got a new phone and can't log onto mxit
Try to log in with the login name you used first see if that works.
I'm trying to log in mxit and it keeps on saying 'connection error please check your GPRS or try again later' could u please help
my mxit says 'connection error please check your GPRS or try again later' could u please help.What must i do?.
2answers
My media center stopped working due to error clr20r3. Could someone help me with this. Thanks.
http://mymce.wordpress.com/2009/07/17/fixing-clr20r3-issue-in-windows-media-center/
Is a site which has some suggestions, every one seems to say the same thing.
you could also poke around on google and use the search of MEDIA CENTER VISTA ERROR CLR20r3
Seems a very common error.
Photoshop Elements 7 is not working on my vaio with vista 64 bit
Starting Adobe Photoshop Elements, the Editor returns the error message "Unable to continue because of hardware or system error. Sorry, but this error is unrecoverable," and the Organizer returns the error message "Interface not found."
Solution: Enable the Event log service.
1. Choose Start > Settings > Control Panel.
2. Double-click Administrative Tools, then Services.
3. Right-click Event Log and select Start.
Note: The Event Log can only be disabled in the Microsoft System Configuration utility (msconfig) under the Services tab, but should never be turned off.
Background information
The error messages "hardware or system error..." or "interface not found" when you start either the Editor or Organizer indicate a system level problem. These messages display if Event Log is disabled. The Event Log is a Microsoft service that should never be disabled.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Windows dvd maker
What OS are you using? Ultimate, Premium, Basic?
Windows DVD Maker has stopped working Issue : While trying to create DVD in Windows DVD Maker in Vista, or while creating a DVD from Windows Movie Maker, which uses Windows DVD Maker, the burn process stops with error message.
Error message : " Windows DVD Maker has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. "
Cause : Windows DVD maker stops working because of incompatibility with one or more codec files which are outdated or incompatible with the particular project or the DVD Maker software itself.
Resolution :
These Codec files should be located and renamed to resolve the issue.
1. Open Start menu and type Event Viewer in the Start menu search bar. Open Event Viewer from the menu.
2. In the Event Viewer window Click on Windows Logs in the left panel
3. Click on Application Logs under Windows Logs
4. Locate error messages listed in the Central panel of the Event Viewer window and double click the error to check if this is log is related to DVD Maker.
Sample Error Log :
Problem signature
Problem Event Name: APPCRASH
Application Name: DVDMaker.exe
Application Version: 6.0.6000.16386
Application Timestamp: 4549b5b0
Fault Module Name: nevideohd.ax
Fault Module Version: 4.6.15.0
Fault Module Timestamp: 459bb828
Exception Code: c0000005
Exception Offset: 00008b89
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1062
5. Locate Fault Module name, it should be a file with extension .ax.
6. Once the file name is identified, try to locate the file in C:/Windows/System32 folder. ( Please click on Show Contents if the files are not listed Automatically ).
7. If the files are not listed in System32 folder, search for the file, with search containing system files and folders.
8. Locate the file and rename it.
9. Check if the issue persists. If the issue persists and the error message again appears, locate the new .ax file that is causing the issue from the Event Viewer, error log.
These steps will resolve the issue instantly without a restart.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
