SOURCE: Parts for numark axis 9
Yes You can get them from Instrumentalparts.com aka www.numarkparts.com
SOURCE: problem with numark axis 9!!
Hi, I’m from Yucatan, Mexico. I’ve always used Numark cd players, I have two Axis8 and two Axis9, and one day I had the same problem with an Axis9. I know a little bit about electronic so I opened the machine and began check it, I took the decision to change and electronic part, I took it from the another Axis9 which was working perfectly, this part is the memory, buffer, effects and it controls all the front panel, jog, play, pitch, etc. I discovered the problem, this electronic circuit part was wrong, I thought that it was impossible to repair so I began to investigate. I visited Numark web site, they sell any electronic part you need, I bought a new one from Numark Company for 200 dollars, and this is the most expensive. They sell parts for Dual Players, Axis, CDX, Mixers, etc. If I not wrong you need this part, now it costs 174 dollars: TWPC01C04603 PCB, Effects/Buffer - Axis 9 (Red) | I got it and my Axis9 works like new again!!! Good luck with yours!
SOURCE: jog wheel doesnt speed up or slow down music in
Get OLD KEVIN 000 THE WIZ to answer it for you
THANKS MUCH
Bufford4
SOURCE: How come my axis 9 cd players pitch control moves on its own?
i take it u know to press key when changing the tempo? if u press key it changes the tempo but keeps the pitch the same. i keep that on all the time. if i want to change the pick i hold key and press either + or -
SOURCE: my axis 9 wont play burnt cds
I'm having the same problem with the Axis 9 I just purchased on eBay. And so is the person who posted "Numark Axis 9's. . Problematic. Ahhhh!!!" Seems ridiculous that this would be so common. I definitely don't want to re-burn 100's of CDs just to use this CD player.
