SOURCE: Magic Chef YE228LV Dryer schematic
dryers only have 1 heating coil and it is located on the back inside panel of the dryer. Before you go taking you dryer's heating coil out please check the temp relay. now some dryers have 2 of thoses they will be on the heating coil case and look like silver button and usually have 1 or 2 wires on it. If the dryer will not dry as well as it use to than what may be happening is that the relay my not be working properly and telling the heating coil to only come on for a short time and than shut off again. now the relay's are the cheapest thing to fix. i would start with thoses. if that does not work or ou need more help please contact me again and i will assist you with disasembling you dryer to get to the heating coil.....
SOURCE: my magic chef dryer heats but will not blow air
A dryer fan is usually directly connected to the motor. If you hear the motor running, maybe the fan broke off, or the duct is really clogged.
SOURCE: Magic Chef Dryer runs fine but Squeaks loudly
this sounds like a drum guides that need replacing soon.
SOURCE: magic chef cye2000ayw will not turn on
Aside from checking the breaker panel, it is likely the lid switch. Only other item that will cause this is the thermal fuse located on the vent after the element.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
SOURCE: how to get at the belt on my Magic Chef Dryer
YOU NEED TO POP THE TOP UP BY GETTING A FLAT SCREWDRIVER OR SOMETHING IN THE GAP UNDER THE LID.
ONCE YOU GOT THE TOP OFF THERE SOULD BE TWO SCREWS HOLDING THE FRONT ON.
