Model number is:WFMC1001uc/09 and ser number is: 857090084493004540. type is: WAM1
SOURCE: Lots of mold and mildew stains on front door seal.
Easy, try running a cup of white vinegar thru the wash cycle. I sell and fix these and it usually work everytime. good luck
SOURCE: The drum on my bosch wfmc1001uc won't spin but it
draining has nothing to do with spinning.
open the back of your machine and you can see the mechanical parts of your washing machine
try to turn it ON , just keep a distance enough for you to see,
1. check the belt if it is attached and aligned (if loose, tighten it a little bit)
2. check if the motor is running ( if not, check the capacitor-small aluminum tube with wires) if busted replace it.
3. check if there is any hamming sound from the motor, if make a humming sound but does'nt rotate, take it out and bring it to machine shop to replace the bearing or bushing
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
SOURCE: bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
SOURCE: Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
