I have a GE Profile JVM1850SH02 microwave. The cooktop / night light is not working. Pushing the buttons on the front of the microwave causes the display to change showing High, Low or Off. I've unplugged the microwave and replaced the bulbs but this did not solve the problem. Everything else is functioning normally. Any suggestions on what I could do to correct this?.
SOURCE: Panasonic NN-P295 Cooktop Light not working
We see (and repair) this
a lot. The problem is on the control panel, which
we regularly repair nationwide by mail for $39.95 postpaid in about a
week.
At
our Web site, you can get details of our service, plus we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
This light failure often
occurs when a bulb goes out and the filament
shorts, or when the bulbs are removed or installed without first
unplugging the oven from the power line. Either can cause such a
failure on the controller.
This can often also
affect the exhaust fan operation, too. The lights and fan can be
inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your
full model number) for more information & help.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: replacement cooktop light bulbs
look inside for a removable panel for access to the lamps. consult your instruction manual.
SOURCE: GE JVM1660 1000 Watts Microwave Oven
This is a problem with the control panel assembly, which we repair nationwide for $39.95. This is usually caused by not disconnecting the microwave from the power line when removing or installing a bulb or by the filaments shorting when the bulb blows. If you decide to send it for service, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: I have installed 2 new light bulbs in my GE
We see (and repair) this a lot. The problem is on the control panel, which
we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at
our Web site, along with a video showing how to remove a typical
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
[email protected]
SOURCE: GE PRofile Microwave runs but no heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
