when you actuate the "engage blade" lever, two things may occur,
First, a mechanical action, a spring moves to put tension onto the belt.
Second; at the end of its run, actuate a switch (PTF switch) to engage the clutch that moves the pulleys that consequentially move the blades.
if the tensioner is not moving , check if spring has come lose, undone or broken, (more likely in your case) or check the PTF switch.
any other assistance, contact me, good luck.
If you need further help, reach me via phone at
https://www.6ya.com/expert/gerardo_79638d1eac6a0a1f
The two Pulleys appear okay. The belt looks looser then it normally does however. But it does not appear the belt is broken. Even if the belt is a little loose fitting. Shouldn't there still be tension when I engage the Lever? Doesn't the tension come from the Spring?
lever arms wont engage husqvarna zero turn
