Need to re-wire my 1993 fxr due to the hacks that butchered it
SOURCE: stock radio wiring diagram
Nissan Xterra Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Gray
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Purple
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Hope this helps!
SOURCE: I need a wiring diagram for a stock radio
this info comes from 12volt.com :
RADIO 12V = yellow
RADIO SWITCH = purple
RADIO ILLUMINATE = red/white
POWER ANTENNA = green/white
LF SPEAKER = (+)blu/wht (-) blu/yel
RF SPEAKER = (+)brown (-) brn/wht
LR SPEAKER = (+)lt. grn (-) blk/yel
RR SPEAKER = (+)blue (-)pink
this info comes from alldata :
LH FR SP (-) GRN/YEL
LH FR SP (+) PPL
RH FR SP (-) BRN/WHT
RH FR SP (+) BRN
BATTERY BLUE
ILLUM CONTROL RED/YEL
LIGHTING YEL/RED
ACC PINK
AMP BLU/WHT
LH RR SP (-) BLK/PNK
LH RR SP (+) ORG
RH RR SP (-) GRY/RED
RH RR SP (+)GRY
Omega and alldata match , i expect the second set to match .
obviously only one of these color codes match your radio , which ever one matches , is the one . cheers
SOURCE: wiring diagram for 2002 kia optima
Not a guarantee but try the kiatechinfo.com in the below information:
Kiatechinfo.com will get you all the information you need when working on a kia 2nd only to a chiltons or haynes manual.
For kiatechinfo.com register (its free) then select the information for
your car make model engine. Then either do a search for timing belt
or pick from proper items in cloumn to the left.
SOURCE: wiring
contact [email protected], they can get you the diagram you need and at a very good price.
