Everything works on the dispenser, but none of the lights come on.
Dear sir,
Reset your water filter indicator light - Most new refrigerators come
equiped with an indicator light that notifies you when it is time to
change your water filter. This light does not automatically reset when
you change your water filter. Here is a list of refrigerator
manufacturers and how to reset the indicator light.
Amana Refrigerators - Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
thanks
good luck
Turn off the fridge. open the Bulbs and get them replaced. If the lights are still not on in that case there is a wiring problem for the power that goes to the light. if that is the case it needs to be reapired by some technician.
Thanks
Go the link http://www.appliance411.com/parts/partsl...
and you can check. Actually specific wiring diagram is not available and moreover if you are not a trained technican I would rather not advise you to try that.
Thanks
Are you talking about the inside lights are the dispenser lights?
The inside lights work fine. It's only the dispenser lights that don't come on.
Everything works fine on my refrigerator, except the dispenser lights do not work. The lights inside the refrigerator work fine as does the dispenser, but none of the dispenser lights work.
I think the individual lights are on a printed circuit board except for the bulb which illuminates the lower area. I have checked that bulb and it is OK. Is there any way I can get a wiring diagram for this unit?
I have checked the large bulb which illuminates the lower dispensing area and it is good. It doesn't light up and the individual dispenser lights (probably led's) which indicate which functions are set on do not work either. Is there a wiring diagram available?
Well, Junoon007 fixed the problem...Thanks. The other responses weren't much help.
