Printing very slow even from internal prints jobs, pausing during prints.
SOURCE: laser jet 2430tn printing slow
Check the way your print Jobs Spool up in your PC. you may have a totally different set up for printing in your new computer that takes two or three extra steps(such as spooling the print job) prior to actually sending it to the printer to be printed. If you have a user manual for your new computer, check the printer set up and see if it is set up to print directly to printer or print to spooling folder then to printer. Also try a different driver if you wish, I know the 2430 can use either PCL5 or PCL6 drivers... I'd start there and see if there is a difference.... the problem isn't your printer obviously its the way your computer is communicating to it. Best of luck to you.
Faxgenius.
SOURCE: Lexmark T642 Slow Slow Printing
I've had this problem with the Lexmarks's T640 printers connected via USB to Mac OS 10.5.5 machines.
Problem: The Mac OS' default resolution of 1200 DPI for this printer causes the printer to have to rasterize the print job again AFTER it arrives at the printer. The printer does a painfully slow job of this.
Solution: Change the default resolution of your print jobs to "600dpi".
Instructions:
1.)Call up the printer settings menu by starting a print job and clicking the up-arrow next to "Printer" box.
2.)Click on the drop-down list with the name of your application and choose "Printer Features".
Change your resolution to "600dpi". Oddly, I find that "1200dpi Image Quality" is almost as fast.
3.)It might be a good idea to "Save as" this new configuration in the "Presets" menu at the top of your list.
You should notice a tenfold increase in the time it takes the printer to actually produce print jobs now.
Additionally, in the "Color Matching" settings (you can get there by changing from the "Printer Features" settings), be sure that you are using "ColorSync" so your printer isn't having to do any additional processing in that area.
SOURCE: Lexmark 2600 not printing
I recently had the same problem. Your Lexmark printer has automatically placed itself on pause. You must go to the control panel and unpause it from there. Its' simple, just go to control panel and select printer and faxes. Select your Lexmark printer and right click it. Then select resume from the drop down menu. Your printer is now unpaused and ready to print!
SOURCE: my printer is in a paused status and i cant unpauseeeit
Hi did u tried to restart the printer if still have the prob please double click on the printer icon comes when u issue a command to the printer check if it shows if there is an error try to cancel the print job which has error and restart the print job if still dosent go on printing just go to controll pannel >fax and printer devices> right click on the lexmark printer icon and remove it and then adda printer put the provided cd with lexmar and reinstall it it should be ok ....
SOURCE: my printer is on pause printing , how to get it off this option
if you can't get it off "pause", then re-install software.
