General Electric WDSR2120J Top Load Washer Logo
A
Anonymous Posted on Mar 05, 2012
I have GE top load washer model WDSR2120J5WW. started making a loud noise when agitating. drum seems loose
2 Related Answers
Anonymous
  • 82 Answers
  • Posted on Jan 23, 2010
SOURCE: how do you remove the front panel on a ge model
Use a small putty knife. Put the putty knife in between the front panel and the top about 3 inches in on the left and right side. You will be inserting it straight in toward the washer and this will release 2 clips and allow the panel to rock towards you. Note some pressure must be applied and will not always release easily. Once the panel rocks toward you there will be 2 clips on the bottom. Just pull off of the clips and you are done. To reassemble allign the panel with the bottom clips and push the top back in, again with a little pressure.
Thank you
Please rate this post
sheakhly
  • 34 Answers
  • Posted on Jun 10, 2011
SOURCE: My GE WBVH5200J2WW Front Load Washer is making a
if you put a large amount of clothes it will make this noise if not you will need to replace the spring inside washing machine
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
My ge wpsf4170 top load washer agitator spins but the drum itself stays stationary.
If the drum spins but the agitator doesn't agitate then its the dog(lil arm things) that grab the agitator ridges to work. If the drum doesn't spin at all its the belt under the drum. it's either broke the belt or has worn and slipped off or the drum was way off balance and kicked it off(belt) . way cheaper to fix either than buy new and most new ones have no agitator anymore so how does it clean better? In my opinion, they don't so I get the parts online at repair clinic and do it my self. Sorry Maytag Repair man. But I saved a lot
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Ge elite 110 23012 100 top load washer
look on the inside your agitator makesure it not strip out cauing your agitator be lose might need to replace agitator
5helpful
2answers
HELLO, WSL100D0WW IS MAKING NOISE ON DRAIN/SPIN CYCLE.
Or, you have coins in your pump casing. Look on the back of the washer, and unscrew the circular port in the bottom right corner. (Keep an 8x13 baking pan underneath, water will escape once you open the chamber). Remove and change/objects from the chamber and replace the port. You should be good to go. This is actually very common for this model washer.
6helpful
3answers
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Washer Clicking/Ticking Noise
Washer is four years old. It makes a loud noise when agitating and now the drum is jammed. What can I do to fix it?
Thanks,
Whirlpool Washer making loud noise during agitation. Agitator appears to be very loose
Does anyone have the name or part number of the piece that needed to be replaced that help stop makes all that noise?
Top General Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
How-2-Repair.com
How-2-Repair.com
Are you a General Washing Machine Expert? Answer questions, earn points and help others
