Check out this affinity manual for error codes on electrolux dryers
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: pf error code on frigidaire gleq2152es
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Did you check the owners manual first to see about the blinking codes?
Usually the codes mean you just have to have factory service remedy the problem!!!!!!!!!!!!!!!
This is a situation that you will need service!
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
SOURCE: frigidaire gallery model # GLG0642AS4 won't
If you have a gas dryer...
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
SOURCE: My Frigidaire model GLEQ2152ES0 will run but the
i have a frigidare electric dryer model gleq2152es it will run but wont heat up and it stops running and starts flashing ad and theselections under starts flashing
Here is a tips that I wrote
that will help to explain why you get the PF Error Code
PF
Error Code for Appliances
heatman101
