Question about Peavey Xr 8600 8 Channel Powered Mixer
Can't get my peavy mixer to recorder from philips cd record
I have a Philips cd Recorder hook up to the Peavey Mixer. CD look like it record. When I take cd out that I record on. There nothing on the cd. I trying to record my sing using a microphone on cd . I had my peavey hook up by the profesional. I add the Phillips cd 2 year later and forgot how to hook it up. I have a red,white cable come from the back of Phillips cd Recorder Audio Out. Going to Record IN on the Peavey Mixer . Also do I need to use another Red,White Cable in order to make it work,
6ya staff
SOURCE:
Anonymous
  • 5 Answers
SOURCE: Peavey PV 2600 and PV 14 mixer blown out by hard
Man, that's a tough one. Best answer I can give, it depends. It would take a tech looking at it and making an evaluation. Sometimes it just takes out the front end (preamps), sometimes it's worse.
Posted on Aug 02, 2009
Anonymous
  • 157 Answers
SOURCE: TRANSISTOR TYPES FOR PEAVEY XR684 MIXER AMPLIFIER/ARRANGEMENT
Go to Peavey's website
http://www.peavey.com
You may find what you are looking for here if not you may have to call them.
Posted on Aug 21, 2009
Fred Yearian
  • 5603 Answers
SOURCE: not recording
You likely have to format the stick from the unit before using. Also there MAY be a size limit for the useable stick.
For a flight case, it is best to find one that SPECIFICALLY mentions use for your unit. Having the supports in the right area to protect the controls is most important.
Posted on Apr 12, 2010
Fred Yearian
  • 5603 Answers
SOURCE: all the channels shows the
It is likely there is a failure of one of the power supply voltages. The solution requires troubleshooting that is NOT DIY unless you are electronically skilled.
Posted on Oct 26, 2010
Fred Yearian
  • 5603 Answers
SOURCE: i have just bought a peavey xr800f powered mixer
There are SEVERAL things to set. First is setting the EFX mix for those channels you want the effects to be active. Next, select the effect you want AND the TIME for the effect and FINALLY the amount of the effect output to go to the MAIN and MONITOR outputs. Also the effect disable button below the effects needs to be in the correct state. ALL of these have to be set for using the effects on the mics.
Posted on Feb 07, 2011
I want to use theMackie as a sub mixer into a powered "all in one" Peavy mixer, where do I come out of the Mackie into one of my powered mixer line inputs?
Take the main outputs into a stereo input (or a pair of mono inputs) on the Peavey - without knowing which Peavey I cannot tell you further info re set-up but as you'll be sending line level signal you'll need to back off the gain on the channels you input to on the Peavey
Nov 17, 2016 | Mackie Music
I want to record using Tascam with my peavey xr1220 mixer
What Tascam recorder are you using? If you are multitracking you will be unlikely to be able to use this mixer. Otherwise get a phono lead to fit the tape out and suitable connections for the Tascam recorder at the other end. This will allow you to record the main mix but unless you are a solo act or putting everything through the PA this will probably be pretty useless to you.
Jan 07, 2015 | Peavey XR 1220 Powered Mixer Mixer Powered
I am trying to connect a computer to a peavey src 4026 to record sermons
Why not un-complicate the circuits by eliminating the soundboard first?
May 11, 2017 | Peavey Music
Peavey 16fx mixer. main outs not working. If you power down the unit and turn on it works for about 5 sec.
Sounds like a power supply failure. Unless you are adept at electroincs this is NOT a DIY repair.
Jul 02, 2011 | Peavey 16fx 16 Channel Mixer W/built In...
Connect Qsc pair kw122 powered speakers and kw 181 powered sub to peavy pv14 mixer?
Two things... Use BALANCED LINES, either XLR or TRS... AND power the mixer from the same receptacle or power conditioner as the speakers and the sub.
Apr 30, 2011 | Peavey Electronics Peavey 00512140 PV 14...
I have a tower computer kind of older . when i plug in the microphone to the back i.e. microphone port, nothing happens to signal it reads the microphone and when i try to use the microphone for fruity...
Assuming you are running windows XP you need to
1. right click the speaker in the lower right corner and select adjust audio properties.
2. Select the audio tab
3. Pull the drop down menu under sound recording and make sure it is selected to your audio driver device. Most are either soundmax, creative(for soundblaster and audigy standalone cards), realtek, or ASUS.
4. Next repeat step one but select open volume control
5. Go to options and then properties
6. Select the circle for recording and make sure your mic input is checked.
7. Close that window and recording mixers will pop up. Select the input you need by checking the box in the lower left corner of the mixer channel. Adjust the level and then use your recording program or sound recorder under Program files>accesories>communication>sound recorder.
Mar 08, 2011 | Philips Phillips...
Can I connect this mixer to a main mixer with 17 channels that is connected to an amplifier?
Yes you can - but do not use the loudspeaker outlets on the rear panel.
There are a variety of outputs on the front panel (bottom right as you look at it).
You can use the main output,  or monitor  send - (for monitor you may need to use the relevant 'send' switches on each channel to send signal to these outputs.
You should also turn the power amp switch to main only (not main + monitor) so that the internal power amplifier is not connected to the monitor socket
You could also use the record out RCA (phono) sockets on the Peavey to connect to the CD / tape input on the main mixer.
You can download a pdf of the manual from here for more informationhttp://www.peavey-eu.com/index.php
Feb 10, 2011 | Peavey XR 8600D Class D Powered Mixer
Expert with the Fostex vf80ex Mixer? What is the success with actually producing a CD, or do you need another writer?
As long as the unit is all working properly I don't see any reason why you can't get good results.Make sure you read the manual carefully. I have one that I picked up cheap but prefer to use my desktop setup for recording as there are tons of Fx and processing patches that you can download for free. Just use good quality blank CDs and you should have no problems.
Jan 07, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Peavey Xr 8600 8 Channel Powered Mixer Logo
59 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
PNiss
Are you a Peavey Music Expert? Answer questions, earn points and help others
