Check your Exposure Compensation Dial. In shooting modes where exposure compensation is allowed, this dial can be set to decrease or increase the brightness of the image in 1/3-stop increments across a range of -2 to 2. You use this control to override the camera's automatic exposure settings to get a slightly darker or lighter image. It should be set to 0.
SOURCE: Digital camera slow reaction times
Nick, check your settings if it is Shutter mode, in this mode you can change how long an exposure is set, maybe your's set more than what you needed.
SOURCE: cannon rebel xt
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=215&modelid=11154#DownloadDetailAct
This is the link for your camera, there is support and service; drivers and downloads etc.
SOURCE: can't take photographs when flash is on
Hi
The powershot s5 IS does in fact have some strange behaviour issues especially on the first rev firmware. For example if you take 15-20 flash photos consecutively without powering down your camera the flash recycle times will increase to about 15sec, so you'll have to wait about 15sec before you can take another flash photo. The work around is to power down the camera and then turn it back ON. Another strange behaviour is manifested by its inability to lock focus after taking a "no-flash" photo, then popping up the flash and trying to take a flash photo. Again the work-around is to power down the camera, pop-up the flash and then power it back up. Confirmed these behaviours in two other cameras of the same model.
SOURCE: High shutter speed causes band of over exposed image
I would suggest to check the lens inside. there might be some kind of small item inserted inside.
check if this happens with no zoom and full zoom.
if the problem persists, I would suggest to first have it checked with another lens just to make sure it's a lens matter.
Then decide if you need to send it back or buy a new lens.
