I need the latest firmware for this model. Please post the link if anyone has it.
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
SOURCE: Will not upgrade to latest firmware
The newest firmware version is actually v 2.01.
The file should be called DI634M_firmware_201.bin and is engineered for North American products only. Does that apply to you?
You can get the file here.
Important! - Make sure that you use only hard-wired network connections for upgrading. Do NOT upgrade firmware on any router over a wireless connection. This might result in a device failure.
Here is also a page with detailed instructions.
If you have any more questions or this doesn't work for you, just come back here and leave a comment - I'm happy to help.
SOURCE: D-link DI-808HV - no response after firmware upgrade
Unfortunatly, from what you are saying it seems that the router is dead.
