SOURCE: Remote died while tv was on Video 2
Why, it is very easy. Just go to Menu manually (as u already did) and select 'Input'. Th eOptions Video1, Video2 and Tuner will scroll up one by one. Just select Tuner
SOURCE: TV screen on video 2 and remote died
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
SOURCE: Accessing Menu Sharp TV
its very easy on the t.v and press on channel up or down on your tv. u will get the screen
SOURCE: Magnavox TV accessing menu without remote
There may be away but need the model number to narrow it down, most remotes can be found at www.vancebaldwin.com and for usaly under $20.00
SOURCE: rca 32v432t
You need the factory remote only for this model of set!
Contact the service rep for your set and order a new remote.
As for the service mode, most RCA sets require an external service interface.
In many models of sets, the results and commands are in HEX. You will need the service manuals, hardware interface, and instrumentation to do proper setups and adjustments.
As for accuracy of adjustments, from factory these sets were very accurate. If there are changes, this is due to failing parts, and not from adjustments going out. The setups are all uPC controled and are exact. The set should be serviced to make it work properly, and not adjusted to offset faults.
Jerry G.
1.
Hold down the
MENU button on the remote and VOLUME DOWN button on the TV it's self at the
same time for at least 4 seconds. The set won't say so, but the lock will be
unlocked
2.
Hold down the 0
(zero) button on the remote and the VOLUME DOWN button on the TV itself at the
unlocked
3.
Hold down the
MENU button on the front of the TV and the TV button on the remote at the same
time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU
button on the front of the TV at the same time for at least 4 seconds.
Most RCA sets use a
four digit code to control the v-chip. The code reset is different depending on
the model. Try each number until you find the one that works for you.
1.
Hold down the
unlocked
2.
Hold down the 0
unlocked
3.
Hold down the
1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Any one amoung the above process will unlock your GE TV. After unlock, you have to do the Vchip-Set.
OK
