Windows XP with Pentium 4
Windows Password Recovery Bootdisk - Free download and software reviews - CNET Download.com download this and reset it
SOURCE: Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
SOURCE: dell dimension 1100 multimedia audio controller xp
Go here for all your drivers.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_CEL_1100&os=WW1&osl=en&catid=&impid=
Please rate this solution
SOURCE: How to remove tower cover...
There are going to be a few small screws on the the back right side (if you are looking at the back of the tower. Remove the the screws from along the edge of the side ( you may have to loosen both sides ) and the case slides towards you then lifts off. If it doesn't budge use a flat head screwdriver to pry in between the cover and tower case and gently slide it towards you. Trust mr it won't break cause it's metal and if it bends you can use pliers to bend it back to shape. Hope the info helps GOD Bless You.
SOURCE: Dell Dimension 2400 Lost Password for Bios
:0 easy
1.) remove the side panel
2.) locate the battery on the main board and remove it
3.) make sure the system is unplugged
4.) press the power button and hold for 10 seconds
5.) replace battery, plug in and power on.
SOURCE: How do I remove the power button on Dell Dimension 8300 desktop
open the side- and along the just inside the front exposed edge there are several tab that get push inward to release the front. They have a tendency to catch again when you go to the next one...you'll just have to play with it a bit. once that is open you'll see the other little plastic tab that holds the switch assembly . Don't forget to UNPLUG the power supply.
