Samsung SGH-A767
SOURCE: call barring password
the default code is the last 4 digits of your phone number unless you have changed it. In that case maybe a retailer could flash your phone back to the default settings.
SOURCE: i have a SGH-A767 SAMSUNG mobile no internet connection
The best way is to call your carrier and get them sent to your phone automatically. To enter them manually:
T-Mobile Browser/Java Settings:
Connection name: T-Zones
Gateway IP address: 216.155.165.050
Secondary IP address: Blank
APN name: wap.voicestream.com
Data bearer: GPRS
Profile name: GPRS
Username: Blank
Bearer: Data
Home page: http://wap.myvoicestream.com
T-Mobile MMS Settings:
WAP Gateway IP Address: 216.155.165.050
APN Name: wap.voicestream.com
Homepage or MMSC URL: Messaging Server: http://mms.msg.eng.t-mobile.com/mms/wapenc
Data Mode: Connection Oriented
AT&T Browser/Java Settings:
Connection name: Internet GPRS
Data bearer: GPRS
Access point name: wap.cingular
User name:
Prompt password: No
Password:
Authentication: Normal or Secure
Gateway IP address: 66.209.11.61
Homepage: http://device.home
Connection security: Off
Session mode: Permanent
AT&T MMS settings:
Connection name: Multimedia
Data bearer: GPRS
User name:
Prompt password: No
Password:
Gateway IP: 66.209.11.61
Homepage or MMSC URL: http://mmsc.cingular.com
Connection Security: Off
Session Mode: Permanent
SOURCE: where is the model code located on a samsung
1. Take off the back cover (battery compartment)
2. Remove the battery
3. Find the model of the phone
SOURCE: Samsung /sgh-a767 how do I reset the phone to
If you forgot your phone code, there is no way to get to your contact list....well, there is no risk free way to get to it. There is a utility (Samsung Code Reader) that you can use which will pull your code from the phone when it is attached by USB to a computer. But beware, as these applets are on sharing websites, so there is no tell if any of them are tainted with viruses.
Otherwise, if you are willing to forego your contact list, then you can hard reset your phone by following these steps:
A couple of things to mention:
1. This fix is NOT for unlocking the network (to use on other carriers), but rather this is for a 4-8 digit phone privacy lock that you may have forgotten what you set it to
2. If you run this fix, it will wipe out all data on the phone, effectively starting from scratch
3. You must remove the SIM card before initiating this or it will be wiped, also, leaving you with need to go buy a new one
4. You need to call Samsung to get the reset code: 800.987.4357 Tell them that you want to hard reset (wipe) your phone and you need the code. (They'll probably stay on the line with you and help you complete the task)
To hard reset the phone
1. Turn off the phone
2. Remove the back cover (battery compartment)
3. Remove the sim card
4. Turn on the phone
5. When it boots up and gets to the error message about the sim, enter the code provided by Samsung and press Return
6. Let the phone restore to original factory image and reboot
7. Turn phone off and install sim card
8. Replace back phone cover
9. Turn on the phone
10. You're ready to roll
