Unplug sewing machine.
Tip machine gently back onto a towel and use a screw driver to remove screws on bottom plate.
If you wish to oil your machine, only oil moving parts with good quality sewing machine oil - no more then one drop. The gears can be greased with Singer lubricant. Of course, never use cooking oil or body oil to oil or grease machine as this can coagulate in the machine and damage it.I hope this helps.
Jimmy
SOURCE: My old Kenmore sewing machine makes a loud squealing noise.
It sounds as if your machine needs a little oiling. If you have a clear machine oil (not 3 in 1). place a drop in the bobbin case area and if you will notice, you will see small holes on the bed and on the top of the machine. place a drop of oil into each of these holes. If you can take the top and bottom covers off, you can put a drop of oil every where you see a hole..some of the machines actually have the oil holes painted a red color. Also place a drop at the handwheel as well. Just remember when oiling, less is better. After oiling, run for a few minutes, if you feel it still needs a litte more, do the same, one drop at a time. After this, if you machine sets for a while, oil just before starting to sew, that way when you put the machine away the oil has been worked through and it should help prevent the squeaking when starting up again.
SOURCE: Beep sound on Kenmore 19233 sewing machine
I had the same problem. Through trial and error, I found the problem was with the thread tension. Usually the thread became wrapped around the spool holder as it was coming off the spool. As you continue to press the pedal, tension is created. When you release the pedal, some slack develop in the threading process and you are able to sew a few more stitches before the beeping starts again.If the thread is caught on the spool holder, simple re-thread the machine.That generally works for me. If it continues to happen, place you thread in a cup behind the machine and thread as usual. You can also purchase an inexpensive thread holder. I made one out of a wood block and other odds and ends found around the house.
SOURCE: Kenmore Sewing Machine 385
check the Bed Drop Lever
Im having the same problem but the lever is not enguaging the bed
SOURCE: kenmore sewing machine model 385 16764
There's a website called managemyhome.com which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
SOURCE: serger
As long as this is a sewing machine and not a serger, I don't know about them. I only tinker on my own. Remove the bottom. There is a rod running along the length of the machine. it needs to be turned 180 degrees. You may need to retime the machine.
