I can't import the pictures from digital camera on my dell computer (windows XP) if i tried message appeared file name or syntax is incorrect.i got new computer and ii have new sony digital camera .please help me.. Thank you
SOURCE: problem with opening ini files...
from each computer:
right click on a .ini file,
select 'open with...'
choose notepad and select the box that says 'always use the selected program to ope this kind of file'
click 'ok'
SOURCE: I have a shortcut to an internet site that has
run a check disk first, those kind of names is not allowed in windows, so it should pop up some error.
in msdos command prompt:
chkdsk C: /F
(assuming it is in drive C)
It should give you an error, saying the volume is locked, so you need to reboot, during the reboot, it will check the file system.
Still in command prompt, just try to delete the file using:
del "??????????" /F/S/Q
USE the quotes please, or it won't work.
OR... the hardway ;) get a Linux Live CD, mount the filesystem, and delete the file.
SOURCE: this is problem in my laptop -- Windows Script
The only position that the ':' ("colon") can appear is immediately before the first '\'' ("slash") -- it's not allowed to have the ':' between the '\' and the 'Microsoft' strings.
SOURCE: Every time I start my
Hope you had deleted some files that relate to your system files.
Try to repair your system by Inserting your Windows XP Service Pack2. in your CD/DVD ROM and boot it again.
And if it's not working than you must format your system.
And installed it.
Here are the procedure to repair/install for reference.
Thanks for Using FixYa
All the Best!
