Long duration of storage might have damaged its inside rubber contacts at key pad. Try if after cleaning. If you wish to know how to clean a remote control, check this link.
Check the pipe feed under the hood for any kinks in the line. Remove the pipe feed carefully and using a high pressure airline, blow back in the reverse direction of the water, back down the washer jet. This fine washer jet is prone to becoming blocked. If you don't have a high pressure airline, then you will need something very fine and flexible, yet stiff enough that when you insert it down the washer jet holes, it can disturb any blockage down there. Although I haven't tried one, you might use a yard brush nylon brush filament.
This machine is a lemon It will break down in a year or less. I have the same machine. The gear box, motor, and now the control board went bad. I haven't been able to use it for 2 months now while they try to fix again & again
have you tried the super cleaner that works to clean just about everything--- vinegar
I dont know for sure if it affects several washers of that model but i have been a appliance tech for 30 years and haven't been to service that problem ever, the cabrio is what i have in my home and love it,cleans well without any foul smells
Hi idyll,
Unless you deleted the email, you can find all your mail under the, All Mail
selection in the left hand column.
By the way, there is no need to ever delete any mail in Gmail, you have plenty
of storage space there. I have been using and saving email for the past 5 years and
am only using 5% of my allotted space, I haven't deleted an email in 5 years.
You could have a seized water pump if you haven't been descaling regularly. Take the pump out and disassemble, clean, reassemble. Work carefully as there are several small parts.
