SOURCE: Lexmark x5470 all in one printer-low ink level
Most likely the cartridge is no longer usable. The ports will eventually become to clogged or the fiber inside the cartridge will not permit the ink to make it to the port and not read as a full cartridge.
SOURCE: Lexmark x2500
Try cleaning the copper plates and install back again if the same message pops up try single cartridge if the error exits with 2 cartridges ,replace the cartridge as lexmark cart has 1 year warranty..
This is the problem because Lexmark cart have inbuild sensor , to by pass is to use original lexmark cart .
SOURCE: refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
SOURCE: refilling lexmark cartridges x2500
There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
For the most optimal output experience with your model, I recommends that you update your printer firmware. The firmware helps ensure that you receive the highest yields of ink available from the cartridges, which offers the greatest value and means fewer necessary cartridge replacements. Please visit the Lexmark website to download and install the Lexmark S300 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
